Home » Eclipse Projects » Eclipse Platform » How to locate a given project given the name and a workspace location
How to locate a given project given the name and a workspace location [message #149290] Sat, 25 October 2003 10:38 Go to next message
Originally posted by: use.reply.to.invalid
We use eclipse for development of several projects sharing subprojects,
and with a final requirement for each project to be able to build
properly from ant.
In order to do so, I would like to write an ant task which can run "ant
clean; cvs update -dP; ant build" for each subproject for the current
project. In order to do so, I need to locate the physical location for
a given subproject, given the name of the subproject (which I find in
..project) and the location of the workspace. It is not enough to
assume the default location in the workspace.
Where would I locate this? My initial attempt at looking at files in
the workspace/.metadata did not make me much wiser, and I don't think
this is stored with the eclipse distribution. I would like a method
that works outside of Eclipse, but if the best way to do this is inside
Eclipse, that would work too. Is there an easy way to get this?
Any suggestions?
Thorbjoern Ravn Andersen "...plus...Tubular Bells!"
Re: How to locate a given project given the name and a workspace location [message #153250 is a reply to message #149290] Wed, 05 November 2003 17:59 Go to previous message
Originally posted by: John_Arthorne.oti.com_
org.eclipse.core.resources plugin provides an ant task called
ConvertPath. Given a resource path (for example "/MyProject") it will
compute the file system path. See javadoc for details.
> properly from ant.
> Any suggestions?
> Best regards,
Previous Topic:[ANN] CodePro Studio NC - non-commercial
Next Topic:AbstractUIPlugin
Current Time: Mon Nov 03 19:09:45 EST 2025
Powered by FUDForum. Page generated in 0.03497 seconds
