Home » Language IDEs » Java Development Tools (JDT) » JUnit: template for run/debug configurations
JUnit: template for run/debug configurations [message #149109] Wed, 17 March 2004 17:03 Go to next message
Is there any way to define template (default values) for JUnit (or any
other) run/debug configurations?
For ex. I need to provide VM arguments to all JUnit tests I run, and right
now I need manually copy it for every new configuration.
thank you
Roman
Re: JUnit: template for run/debug configurations [message #149140 is a reply to message #149109] Wed, 17 March 2004 17:35 Go to previous message
We did just add https://bugs.eclipse.org/bugs/show_bug.cgi?id=37862
Which would allow you to create a Installed JRE for use with your JUnit
testing and configure it with the correct set of VM arguments.
This is in the latest integration build (I20040317)
HTH
Darins
"Roman Dolgov" <roman_dolgov@yahoo.com> wrote in message
news:c3ahng$vbl$1@eclipse.org...
> thank you
> Roman
Previous Topic:Ant script stalls
Next Topic:Java 1.5.0 Exceptions, Ant, and building outside of Eclipse
Current Time: Thu Nov 06 13:59:04 EST 2025
Powered by FUDForum. Page generated in 0.04305 seconds
