| Re: Jvm termination during opening of eclipse.exe in enterprise linux ws 4 [message #149232 is a reply to message #149107] |
Tue, 18 April 2006 19:29  |
sudhanshu wrote:
> hi
> I have installed eclipse and j2re 1.4.2_08 in enterprise linux ws 4
> .But when i open eclipse.exe then it is not opened and JVM Is terminated.
> please anyone solve my problem. I shall be
> very thankful for this.......
> sudhanshu..
Well, the eclipse.EXE part scares me... Eclipse for Linux doesn't have
the Windows extension!
But assuming that was a temporary mind cramp, or just a "you know what I
meant" kind of thing... How are you starting up Eclipse? If from a
command line, are you specifying the JRE on the command line (-vm
option)? Or is the JRE in your path (and EARLIER in your path than any
other JVM?)?
Try "type java" at a command line and see which java it thinks you're
running; and/or try "java -showversion to see which one you're getting.
RDS
Randy D. Smith randy (dot) d (dot) smith (at) intel (dot) com
Eclipse TPTP Committer, Platform Proj (data collection/agent controller)
FUDForum. Page generated in 0.08443 seconds
