Home » Language IDEs » C / C++ IDE (CDT) » windows resource files
windows resource files [message #149027] Sat, 16 July 2005 08:18 Go to next message
Dear all,
I want to add a resource file for my win32 app. My project is a managed
build C++ project. Now I am stuck on how to just add a resource file and
compile it along with the code:
1. MinGW doesn't come with a resource compiler as far as I know;
2. Even if I get one resource compiler I don't know how to integrate it to
the CDT environment. I still want to use the managed build feature.
Could anyone give me a hand?
Ben
Re: windows resource files [message #149043 is a reply to message #149027] Sat, 16 July 2005 11:27 Go to previous messageGo to next message
Originally posted by: j_apter.hotmail.com
I believe MinGW comes with windres (Windows resource file compiler). As
for integrating it into a managed make in CDT, I don't know, hopefully
someone else can answer that...
benben wrote:
> Dear all,
> Ben
Re: windows resource files [message #149059 is a reply to message #149043] Sat, 16 July 2005 21:18 Go to previous messageGo to next message
Ok, as there is only one and written resource file, I can really manually
compile it separately. But is there a way to tell the linker to link with
resource? Or, is there a way to add a few lines to the make file and still
have the managed build system going?
ben
Re: windows resource files [message #149122 is a reply to message #149059] Sun, 17 July 2005 23:10 Go to previous messageGo to next message
> ben
We should add handling of windres to the gnu on windows toolset. If it's
not there, please raise a bug in bugzilla.
Doug
Re: windows resource files [message #149502 is a reply to message #149059] Mon, 18 July 2005 06:25 Go to previous messageGo to next message
Yes, you can add the compiled resource like every other library. If
there is maybe an icon resource, you can name it "libicon.a" and add it
as "icon" to Properties-> Build-> Linker-> Libraries. After that you can
load the resource and access the members by resource-id.
Re: windows resource files [message #149524 is a reply to message #149502] Mon, 18 July 2005 23:26 Go to previous messageGo to next message
Thanks for your reply! That solves my problem!
I'm thinking, C++ guys hardly do Java, but since CDT is written in java and
without a C++ interface, to extended is kinda hard for us...
ben
Re: windows resource files [message #149636 is a reply to message #149027] Wed, 20 July 2005 09:29 Go to previous messageGo to next message
Originally posted by: david.wrigley.zen.co.uk
Not sure if this is the best way...
1. I create a batchfile (res.bat) in the workspace for the project.
This contains one line:
windres --use-temp-file -i myfilename.rc -o Debug\myfilename_rc.o --define
__WXMSW__ --define __WXDEBUG__ --include-dir c:\wxwin\include
--include-dir c:\wxwin\lib\gcc_lib\mswd --include-dir .
(as you can see, this is using wxwidgets, so yours may be different)
2. I create a builder in 'Project / Properties/ Builders' called Resources
With location ${workspace_loc:/myprojectfolder/res.bat}
and ${workspace_loc:/myprojectfolder}
Works fine for me
Would like to know if there is a better way.
Re: windows resource files [message #149690 is a reply to message #149636] Thu, 21 July 2005 07:57 Go to previous messageGo to next message
> Works fine for me
Thanks David! I can see that's a good point. I have never added a builder
before! So these are all the little things I have to handle switching from
Visual Studio...
Ben
Re: windows resource files [message #794958 is a reply to message #149690] Thu, 09 February 2012 17:41 Go to previous message
This works too:
Project | Properties | C/C++-Build | Settings | Build Steps | Pre-Build Steps | Command: windres --use-temp-file -i..\MyProject.rc -o..\MyProject_rc\MyProject_rc.o
Tool Settings | MinGW C++ Linker | Miscellaneous | Other Objects
click the icon 'Add'
fill in "C:\MyWorkspace\MyProject\MyProject_rc\MyProject_rc.o"
You have to add the folder .\MyProject_rc before you build
Previous Topic:Compiling Windows resources (.rc)
Next Topic:Resource-scriptfiles, Win32API
Current Time: Sun Aug 31 07:49:50 EDT 2025
Powered by FUDForum. Page generated in 0.12425 seconds
