Home » Language IDEs » ServerTools (WTP) » wtp m9, web services tutorial - error protocol = http host = null
wtp m9, web services tutorial - error protocol = http host = null [message #149025] Thu, 24 November 2005 13:56 Go to next message
I try web services tutorial for wtp m9
my environment : eclipse 3.1.1 linux gtk, emf-xsd-sdo 2.1.1 gef 3.1.1, ve
1.1.0.1, wtp 1.0m9 - all sdk
tomcat 5.5.12
i haven't proxy
on the end of web service clinet building i get next error
java.lang.IllegalArgumentException: protocol = http host = null
sun.net.spi.DefaultProxySelector.select(DefaultProxySelector .java:146)
sun.net.www.protocol.http.HttpURLConnection.plainConnect(Htt pURLConnection.java:739)
sun.net.www.protocol.http.HttpURLConnection.connect(HttpURLC onnection.java:669)
sun.net.www.protocol.http.HttpURLConnection.getInputStream(H ttpURLConnection.java:913)
at java.net.URL.openStream(URL.java:1007)
org.eclipse.jst.ws.internal.consumption.ui.widgets.test.wssa mple.GSTCLaunchCommand.launchSample(GSTCLaunchCommand.java:1 24)
org.eclipse.jst.ws.internal.consumption.ui.widgets.test.wssa mple.GSTCLaunchCommand.execute(GSTCLaunchCommand.java:62)
org.eclipse.jst.ws.internal.consumption.ui.widgets.test.Clie ntTestDelegateCommand.commandFactoryExecution(ClientTestDele gateCommand.java:108)
org.eclipse.jst.ws.internal.consumption.ui.widgets.test.Clie ntTestDelegateCommand.execute(ClientTestDelegateCommand.java :89)
org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.runCommand(CommandFragmentEngine.java:348)
org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.visitTop(CommandFragmentEngine.java:312)
org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.moveForwardToNextStop(CommandFragmentEngine.jav a:220)
org.eclipse.wst.command.internal.env.ui.widgets.SimpleComman dEngineManager$4.run(SimpleCommandEngineManager.java:204)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:346)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:291)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 830)
org.eclipse.wst.command.internal.env.ui.widgets.SimpleComman dEngineManager.runForwardToNextStop(SimpleCommandEngineManag er.java:175)
org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.runForwardToNextStop(WizardPageManager.java:78)
org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.performFinish(WizardPageManager.java:227)
org.eclipse.wst.command.internal.env.ui.widgets.DynamicWizar d.performFinish(DynamicWizard.java:334)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:676)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:349)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1021)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2867)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2572)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
at org.eclipse.jface.window.Window.open(Window.java:787)
at org.eclipse.ui.actions.NewWizardAction.run(NewWizardAction.j ava:181)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
at org.eclipse.jface.action.ActionContributionItem.access$
(ActionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Re: wtp m9, web services tutorial - error protocol = http host = null [message #150266 is a reply to message #149025] Thu, 01 December 2005 05:14 Go to previous message
Looks like bug 105090, which should be fixed in 1.0. If you can,
verify that it's not still a problem when using a 1.0 Release Candidate.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=105090
- Nitin
Previous Topic:WTP 1.0M9 available for download!
Next Topic:Why I can't see any files under /lib?
Current Time: Sat Nov 22 01:58:20 EST 2025
Powered by FUDForum. Page generated in 0.04275 seconds
