Home » Eclipse Projects » Eclipse Platform » setActiveEditor not called when editor is selected.
setActiveEditor not called when editor is selected. [message #148927] |
Fri, 24 October 2003 01:00  |
I need to set the status of an action based every time an editor is
selected.
My thought was to create a viewer contribution in ui.popupMenus where that
contribution is an IEditorActionDelegate.
I guessed that setActiveEditor would be called every time an editor is
selected. It is called when an editor is first opened up ... but not when
switching between two editors that are already opened.
Was wondering ... anyone know how can I hook into an editor being selected?
Brett
Re: setActiveEditor not called when editor is selected. [message #149005 is a reply to message #148982] |
Fri, 24 October 2003 07:57   |
Hmmm ... apologize for being ambigious.
By selected I mean ... if there were two editors tabs currently in eclipse,
seleting here means clicking on a tab. So for example, if there were two
editors, Editor1 and Editor2, if I clicked on the Editor1 tab, I am
selecting it. (Is that the same as activating?)
So, now, if I were to repeateadly click the Editor1 tab followed by the
Editor2 tab, I am interested in having my any of my IEditorActionDelegate's
methods to be called (either selectionChanged or activeEditor.)
According to your note, it seems that my some of my Action's methods should
be called since it is a subclass of ActionDelegate ... but I just verified
that they aren't ;-(
To veify, in my Action, I put a breakpoint in selectionChanged and
setActiveEditor methods. They are called initially, but at some point in
time, I can switch between the two editors, and no breakpoints are hit ...
or did I totally screw this up?
Brett
"Daniel Megert" <daniel.megert@gmx.net> wrote in message
news:bnam5n$1s5$1@eclipse.org...
> >selected.
that
selected?
> By selected you mean activated I guess. There are two ways to do this:
> 1. add a part listener (see IPartListener and IPartListener2) to the
> workbench page
> 2. add a selection listener
> Note: if your action is an action delegate then it will be informed
> automatically about selection changes.
> Dani
> >Brett
Re: setActiveEditor not called when editor is selected. [message #149611 is a reply to message #149005] |
Mon, 27 October 2003 04:37   |
Yes. The active part (view or editor) is the one with the blue tite bar/tab.
It depends how you registered the delegate: if you did this via XML then
selectionChagend(...) should be called (if not it's a bug). If you
created the action in code then it is your responsibility to register
them as selection dependent actions. The following links might help:
- TextEditorAction
- RetargetTextEditorAction
- AbstractTextEditor.markAsSelectionDependentAction()
Dani
>Brett
>>>selected.
>that
>selected?
>>workbench page
>>Dani
>>>Brett
Re: setActiveEditor not called when editor is selected. [message #149744 is a reply to message #149611] |
Mon, 27 October 2003 09:27   |
The action was registered via XML ...
news:bniouh$md5$1@eclipse.org...
eclipse,
bar/tab.
should
verified
> - TextEditorAction
> Dani
> >Brett
> >>>selected.
> >that
when
> >selected?
> >>workbench page
> >>Dani
> >>>Brett
Re: setActiveEditor not called when editor is selected. [message #150105 is a reply to message #149744] |
Tue, 28 October 2003 06:36   |
How did you do it?
>eclipse,
>bar/tab.
>should
>verified
>>- TextEditorAction
>>Dani
>>>Brett
>>>>>selected.
>>>that
>when
>>>selected?
>>>>workbench page
>>>>Dani
>>>>>Brett
Re: setActiveEditor not called when editor is selected. [message #150508 is a reply to message #150105] |
Wed, 29 October 2003 00:22  |
Viewer contribution listed below ... via <extension
point="org.eclipse.ui.popupMenus">
<viewerContribution
targetID="#TextEditorContext"
id="net.sourceforge.perforce.ui.EditorViewSubmitContribution ">
<action
label="%submit.label"
class="net.sourceforge.perforce.ui.action.SubmitIResourceAction "
menubarPath="additions"
enablesFor="+"
id="net.sourceforge.perforce.ui.action.submitIResourceAction ">
</action>
</viewerContribution>
This was posted earlier
news:bnlk9p$knm$1@eclipse.org...
> How did you do it?
> >eclipse,
two
> >bar/tab.
the
> >should
> >verified
in
> >>- TextEditorAction
> >>Dani
> >>>Brett
> >>>>>selected.
> >>>that
is
> >when
> >>>selected?
> >>>>workbench page
> >>>>Dani
> >>>>>Brett
Current Time: Mon Jul 14 20:29:29 EDT 2025
Powered by FUDForum. Page generated in 0.07026 seconds
