A question re: GUI apps [message #148834] |
Thu, 14 July 2005 16:44  |
Originally posted by: eclipse.rocketcomp.com.au
Coming from a Windows background, I have successfully used eclipse/cdt to
develop console apps.
My question is, what are the options available for writing GUI apps targetting
Linux ?
Re: A question re: GUI apps [message #148962 is a reply to message #148956] |
Fri, 15 July 2005 19:44   |
Originally posted by: j_apter.hotmail.com
I have recently been looking into a GUI toolkit as well. I mainly write
backend/daemon type applications so I haven't done much GUI work myself.
The latest version of Qt looks pretty nice, though, wxWidgets
(http://www.wxwidgets.org/) seems a bit more tempting mainly because its
free and you can use it in commercial applications. I also believe that
Qt requires the use a special preprocessor before actually compiling with
a C++ compiler, this just sounds like more Makefile headaches to me (this
may have changed though). This page has some pretty good info that seems
to somewhat objectively compare different GUI toolkits:
http://wiki.wxwidgets.org/wiki.pl?WxWidgets_Compared_To_Othe r_Toolkits
Let us know what you end up with...
Ian Semmel wrote:
> Yes, thanks for that. I have downloaded Qt and am investigating. It seems
fairly
> comprehensive.
> David H wrote:
>>> to develop console apps.
>>> targetting Linux ?
>>> Thanks
>> Haven't done much of this myself, but you will probably want to look
>> into one of the gui toolkits available like qt and gtk.
>> The nice thing about developing under either of these is that they are
>> easily portable (at least the gui part of it) to windows using the
>> windows version of these kits.
>> http://www.trolltech.com/products/qt/
>> http://www.gtk.org/
>> They have different licensing schemes. Both are open source, but QT
>> provides a pay for license if you plan to develop a closed source
>> application. GTK on the other hand is lgpl which allows you to use it
>> in either open or closed source apps for free.
>> Also, qt is generally associated with kde while gtk is associated with
>> gnome. While this doesn't mean kde users can't use a gtk product, and
>> visa versa, it does mean they may not have the libraries pre-installed.
>> I'm sure there are other options as well.
>> HTH
Re: A question re: GUI apps [message #149115 is a reply to message #149093] |
Sun, 17 July 2005 23:07  |
Originally posted by: dschaefer.rogers.com
Stanimir Stamenkov wrote:
> /Miguel Simon/:
>> Yes, I am aware of VEP. I mean a GUI RAD based on C/C++.
> And Eclipse is Java based. I'm still not sure what you're after -
> creating an Eclipse plug-in which uses Java (it has to anyway) only for
> interface with Eclipse? I think VEP is what you could need, but it needs
> module created for WxWidgets, I guess.
I remember talking to the VEP guys about integrations with the CDT.
There is definitely potential there but it would be a lot of work. Worth
looking into, though.
BTW, I'd pick wxWidgets because of its licensing as someone mentioned
previously in this thread. Not to get widget wars started...
Doug
FUDForum. Page generated in 0.44123 seconds
