Home » Language IDEs » ServerTools (WTP) » M9 - no perspective
M9 - no perspective [message #148821] Thu, 24 November 2005 02:35 Go to next message
I opened a "fresh" eclipse 3.1.1 and in it added:
emf-sdo-SDK-2.1.1
GEF-SDK-3.1.1
JEM-SDK-1.1.0.1
and
wtp-1.0M9
When I started eclipse there was no J2EE perspective, and when trying to
create a new project, none of the WTP related projects were available (e.g.,
dynamic web project).
What did I do wrong?
Re: M9 - no perspective [message #148831 is a reply to message #148821] Thu, 24 November 2005 03:03 Go to previous messageGo to next message
I think you've installed it wrong. I see the J2EE perspective and project
types just fine. You might want to try again.
Re: M9 - no perspective [message #148854 is a reply to message #148831] Thu, 24 November 2005 04:02 Go to previous messageGo to next message
I tried it again, but again - the same...
How can tell know what is wrong (logs somewhere or anything)?
"craig" <csalter@ca.ibm.com> wrote in message
news:94abf7c4e9b0655de968b480672d6c85$1@www.eclipse.org...
Re: M9 - no perspective [message #148892 is a reply to message #148821] Thu, 24 November 2005 07:50 Go to previous messageGo to next message
Zohar wrote:
> Hello,
> emf-sdo-SDK-2.1.1
> GEF-SDK-3.1.1
> JEM-SDK-1.1.0.1
> and
> wtp-1.0M9
Are you sure you downloaded "wtp-1.0M9"; or was it "wst-1.0M9" by accident ?
Window -> Open Perspective ... -> Other -> J2EE ????
Darryl
Re: M9 - no perspective [message #148922 is a reply to message #148892] Thu, 24 November 2005 10:36 Go to previous messageGo to next message
here's a copy/paste of it:
wtp-1.0M9.zip
I deleted the eclipse dir, opened eclipse 3.1.1 into a new dir, opened all
prerequisites and then the WTP.
And there's no perspective... :(
"Darryl L. Miles" <darryl@netbauds.net> wrote in message
news:4385B724.1000903@netbauds.net...
> Zohar wrote:
>> Hello,
>> emf-sdo-SDK-2.1.1
>> GEF-SDK-3.1.1
>> JEM-SDK-1.1.0.1
>> and
>> wtp-1.0M9
>> (e.g., dynamic web project).
> Darryl
Re: M9 - no perspective [message #148929 is a reply to message #148922] Thu, 24 November 2005 10:43 Go to previous messageGo to next message
Take a look at Help -> About
Can you see WST or JST plugins in there.
Check out the "View Error Log" for reasons why they may not be
activating if they are in there.
> wtp-1.0M9.zip
Re: M9 - no perspective [message #148935 is a reply to message #148892] Thu, 24 November 2005 10:45 Go to previous messageGo to next message
I'm attaching the feature's list I have in the about screen...
Does this help?
> Zohar wrote:
>> Hello,
>> emf-sdo-SDK-2.1.1
>> GEF-SDK-3.1.1
>> JEM-SDK-1.1.0.1
>> and
>> wtp-1.0M9
>> (e.g.,
> Darryl
  • Attachment: features.jpg
    (Size: 73.58KB, Downloaded 133 times)
Re: M9 - no perspective [message #149004 is a reply to message #148929] Thu, 24 November 2005 10:50 Go to previous messageGo to next message
looks normal...
news:4385DFB8.401@netbauds.net...
>> wtp-1.0M9.zip
>> all
  • Attachment: .log
    (Size: 0.54KB, Downloaded 125 times)
Re: M9 - no perspective [message #149011 is a reply to message #148935] Thu, 24 November 2005 11:42 Go to previous messageGo to next message
The feature set it not that normal, the plugin list is...
Have you looked for the button Configuration Details -> View Error Log
> Does this help?
>>Zohar wrote:
>>>Hello,
>>>emf-sdo-SDK-2.1.1
>>>GEF-SDK-3.1.1
>>>JEM-SDK-1.1.0.1
>>>and
>>>wtp-1.0M9
>>>(e.g.,
>>Darryl
Re: M9 - no perspective [message #149019 is a reply to message #148935] Thu, 24 November 2005 12:49 Go to previous messageGo to next message
Check your Error Log view (open via Window-Show View). M9 may have had
some problem initializing one of it's plugins - it would be logged
there. This might happen if the workspace that you were using was
previously used by an earlier release. If so, try specifying a new
workspace when starting M9. If that works, delete the contents of the
old <workspace>\.metadata folder (though doing so will of course 'clean'
your prefences, histories etc)...
> Does this help?
>>Zohar wrote:
>>>Hello,
>>>emf-sdo-SDK-2.1.1
>>>GEF-SDK-3.1.1
>>>JEM-SDK-1.1.0.1
>>>and
>>>wtp-1.0M9
>>>(e.g.,
>>Darryl
Re: M9 - no perspective [message #149034 is a reply to message #148821] Thu, 24 November 2005 14:11 Go to previous messageGo to next message
Zohar wrote:
> Hello,
> emf-sdo-SDK-2.1.1
> GEF-SDK-3.1.1
> JEM-SDK-1.1.0.1
> and
> wtp-1.0M9
eclipse 3.1.x have problem with plugin upgrade (maybe only for webtools)
i do next :
close eclipse
remove directories start with org.eclipse.* in ECLIPSE_HOME/configuration
start eclipse
add extensions (if exists)
regards
Re: M9 - no perspective [message #149042 is a reply to message #149034] Thu, 24 November 2005 13:52 Go to previous messageGo to next message
Originally posted by: weconsul.ptd.net
Haris Peco wrote:
> Zohar wrote:
>> Hello,
>> emf-sdo-SDK-2.1.1
>> GEF-SDK-3.1.1
>> JEM-SDK-1.1.0.1
>> and
>> wtp-1.0M9
> i do next :
> close eclipse
> start eclipse
> regards
When you restart Eclipse did you start it with the '-clean' option..
Thanks in Advance...
IchBin, Pocono Lake, Pa, USA
http://weconsultants.servebeer.com/JHackerAppManager
____________________________________________________________ ______________
'If there is one, Knowledge is the "Fountain of Youth"'
-William E. Taylor, Regular Guy (1952-)
Re: M9 - no perspective [message #149050 is a reply to message #149042] Thu, 24 November 2005 15:51 Go to previous messageGo to next message
IchBin wrote:
> Haris Peco wrote:
>> Zohar wrote:
>>> Hello,
>>> emf-sdo-SDK-2.1.1
>>> GEF-SDK-3.1.1
>>> JEM-SDK-1.1.0.1
>>> and
>>> wtp-1.0M9
>> i do next :
>> close eclipse
>> start eclipse
>> regards
yes, but i think that it isn't important when you remove
ECLIPSE_HOME/configuration/org.eclipse.*
Re: M9 - no perspective [message #149263 is a reply to message #149019] Sun, 27 November 2005 01:53 Go to previous messageGo to next message
I have this in the error log:
Error 2005-11-24 17:23:52.215 Referenced part does not exist yet:
org.eclipse.ui.views.TaskList.
"John O'Shea" <john.oshea@capeclear.com> wrote in message
news:dm4ueu$kta$1@news.eclipse.org...
> some problem initializing one of it's plugins - it would be logged there.
> This might happen if the workspace that you were using was previously used
> by an earlier release. If so, try specifying a new workspace when
> starting M9. If that works, delete the contents of the old
> <workspace>\.metadata folder (though doing so will of course 'clean' your
>> Does this help?
>>>Zohar wrote:
>>>>Hello,
>>>>emf-sdo-SDK-2.1.1
>>>>GEF-SDK-3.1.1
>>>>JEM-SDK-1.1.0.1
>>>>and
>>>>wtp-1.0M9
>>>>(e.g.,
>>>accident ?
>>>Darryl
Re: M9 - no perspective [message #149268 is a reply to message #149011] Sun, 27 November 2005 01:56 Go to previous messageGo to next message
news:4385ED6B.3050103@netbauds.net...
>> Does this help?
>>>Zohar wrote:
>>>>Hello,
>>>>emf-sdo-SDK-2.1.1
>>>>GEF-SDK-3.1.1
>>>>JEM-SDK-1.1.0.1
>>>>and
>>>>wtp-1.0M9
>>>>(e.g.,
>>>accident
>>>Darryl
  • Attachment: log.dat
    (Size: 0.54KB, Downloaded 122 times)
Re: M9 - no perspective [message #149427 is a reply to message #149263] Sun, 27 November 2005 02:49 Go to previous messageGo to next message
Looks like an unrelated error to me.
>>>>Zohar wrote:
>>>>>Hello,
>>>>>emf-sdo-SDK-2.1.1
>>>>>GEF-SDK-3.1.1
>>>>>JEM-SDK-1.1.0.1
>>>>>and
>>>>>wtp-1.0M9
>>>>>(e.g.,
All I can say is that under both Win32 and Linux folling the above
instructions does work for me. However I have downloaded the SDK
versions of the platform and WTP as well rather than the runtime only
versions.
$ md5sum eclipse-SDK-3.1.1-win32.zip eclipse-SDK-3.1.1-linux-gtk.tar.gz
emf-sdo-xsd-SDK-2.1.1.zip GEF-SDK-3.1.1.zip JEM-SDK-1.1.0.1.zip
wtp-sdk-1.0M9.zip
79d9f15b83e501259c44355ffef98070 eclipse-SDK-3.1.1-win32.zip
a2ae61431657e2ed247867b9a9948290 eclipse-SDK-3.1.1-linux-gtk.tar.gz
261fb17642b1f5df0244b47e37e207e0 emf-sdo-xsd-SDK-2.1.1.zip
70a6de96c4edbc8903f6bd964039ddc8 GEF-SDK-3.1.1.zip
988c77bb07a6993e9f08704b0fec5068 JEM-SDK-1.1.0.1.zip
299f101aec7d3786d9a1a8349f48d37c wtp-sdk-1.0M9.zip
MD5SUM.EXE for DOS/WIN32 at http://www.etree.org/md5com.html
Darryl
Re: M9 - no perspective [message #149438 is a reply to message #148821] Sun, 27 November 2005 20:08 Go to previous messageGo to next message
Mr Zohar
If you have not resolved your problem try this (I'm supposing you are
working in a Windows environment):
1. Download (If you have not don yet) and extract the following zip files
in the given order:
1. eclipse-SDK-3.1.1-win32.zip
2. emf-sdo-xsd-SDK-2.1.1.zip
3. GEF-ALL-3.1.1.zip
4. JEM-SDK-1.1.zip
5. wtp-sdk-1.0M9.zip
If you are plannig to use EMF you should also download and unpack
uml2-SDK-1.1.1.zip
6. Create a new directory and name as you wish, to use it as a workspace.
7. Start eclipse
8. In the "Select a Workspace" window, select the directory you created in
step 6
9. See if you have the J2EE Perspective by selecting Window > Open
Perspective > Other
I'm pretty sure it works. As I have a lot of other stuff in my Eclipse
environment y installed a new one with the objects in the list to make
sure it will work for you.
Good luck.
Re: M9 - no perspective [message #149495 is a reply to message #149438] Mon, 28 November 2005 03:02 Go to previous message
I tried using emf-sdo-SDK-2.1.1.zip instead of emf-sdo-xsd-SDK-2.1.1.zip.
Now that I downloaded the correct one I have the J2EE back - thank you.
"Antonio Gurisatti" <maguri@epm.net.co> wrote in message
news:3c3fdf10494d2b3b4392f1274e3354bf$1@www.eclipse.org...
> Mr Zohar
> in the given order:
> 4. JEM-SDK-1.1.zip
> uml2-SDK-1.1.1.zip
> 7. Start eclipse
> step 6
> Perspective > Other
> Good luck.
Previous Topic:tutorial:cmp school scehdule
Next Topic:context path
Current Time: Sun Aug 31 22:35:31 EDT 2025
Powered by FUDForum. Page generated in 0.09196 seconds
