Home » Eclipse Projects » Subversive » Proxy
Proxy [message #13869] Fri, 22 February 2008 04:29 Go to next message
now that subversive is under the Eclipse umbrella, are there any plan to
use the standard proxy setting from Eclipse?
Eclipse offers the possibility to maintain the proxy settings under Window
-> Preferences -> General -> Network connections.
I believe that subversive should use this settings instead of having the
user to maintain the data again in the SVN client.
Best regards, Lars
Re: Proxy [message #13916 is a reply to message #13869] Tue, 04 March 2008 11:12 Go to previous message
Originally posted by: alexander.gurov.polarion.org
Dear Lars,
Thank you for your tip. It is really good idea, but we have some problems
related to SVN connectors API:
1) Proxy configuration API now exists only for SVN Kit-based connector
2) SVN Kit proxy configuration API does not allow to define "proxy
exclude" settings.
So, regarding to this I cannot inform you when this task can be done.
Lars Vogel wrote:
> Best regards, Lars
Dear Lars,
Yes, we have plan
Previous Topic:Subversive and Subversion 1.5
Next Topic:Can't diff between versions in branch
Current Time: Fri Jul 11 22:20:06 EDT 2025
Powered by FUDForum. Page generated in 0.04988 seconds
