Home » Language IDEs » Java Development Tools (JDT) » Exception running eclipse
Exception running eclipse [message #148769] Mon, 15 March 2004 15:15 Go to next message
nyone have a solution for this clean install problem??
ENTRY org.eclipse.core.launcher 4 0 Mar 15, 2004 14:18:21.136
!MESSAGE Exception launching the Eclipse Platform:
!STACK
at org.eclipse.ui.keys.KeyStroke.hashCode(KeyStroke.java:308)
at java.util.HashMap.hash(HashMap.java:250)
at java.util.HashMap.get(HashMap.java:301)
org.eclipse.ui.internal.commands.KeySequenceBindingNode.add( KeySequenceBindingNode.java:175)
org.eclipse.ui.internal.commands.KeySequenceBindingMachine.v alidateTree(KeySequenceBindingMachine.java:231)
org.eclipse.ui.internal.commands.KeySequenceBindingMachine.v alidateSolution(KeySequenceBindingMachine.java:210)
org.eclipse.ui.internal.commands.KeySequenceBindingMachine.g etKeySequenceBindingsByCommandId(KeySequenceBindingMachine.j ava:73)
org.eclipse.ui.internal.commands.CommandManager.calculateKey SequenceBindings(CommandManager.java:274)
org.eclipse.ui.internal.commands.CommandManager.readRegistry (CommandManager.java:715)
org.eclipse.ui.internal.commands.CommandManager.<init>(CommandManager.java:233)
org.eclipse.ui.internal.commands.CommandManager.<init>(CommandManager.java:196)
org.eclipse.ui.commands.CommandManagerFactory.getCommandMana ger(CommandManagerFactory.java:41)
org.eclipse.ui.internal.commands.ws.WorkbenchCommandSupport. <init>(WorkbenchCommandSupport.java:49)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:767)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1503)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:265)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:139)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:47)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:257)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:104)
at org.eclipse.core.launcher.Main.basicRun(Main.java:279)
at org.eclipse.core.launcher.Main.run(Main.java:742)
at org.eclipse.core.launcher.Main.main(Main.java:581)
!SESSION
!ENTRY org.eclipse.core.launcher 4 0 Mar 15, 2004 14:19:51.251
!STACK
!SESSION
!ENTRY org.eclipse.core.launcher 4 0 Mar 15, 2004 14:56:42.146
!STACK
Re: Exception running eclipse [message #148802 is a reply to message #148769] Mon, 15 March 2004 18:34 Go to previous message
Originally posted by: newsserver_mails.bodden.de
Eclipse Version? JRE ? Platform? OS?
Eric
Eric Bodden
ICQ UIN: 12656220
Website: http://www.bodden.de
PGP key available
Previous Topic:Call hierarchy mislead
Next Topic:changing templates and javadoc tags in eclipse
Current Time: Sun Nov 23 07:39:44 EST 2025
Powered by FUDForum. Page generated in 0.03571 seconds
