Home » Language IDEs » C / C++ IDE (CDT) » "file not indexed because it was not built" errors
"file not indexed because it was not built" errors [message #148756] Wed, 13 July 2005 19:21 Go to next message
Originally posted by: yug3sh.yahoo.com
I seem to be getting this error for all the header files (*.h) in my
project. What does this mean, and how do I get rid of it?
Thanks.
Re: "file not indexed because it was not built" errors [message #148983 is a reply to message #148756] Fri, 15 July 2005 21:03 Go to previous messageGo to next message
Originally posted by: plankton.softwitch.net
Older version of cdt contains that problems. Try it with newer. Newer
version of cdt can indexing without building.
If you want to keep version of cdt, you have to make makefile manually,
or main function have to includes target header files in any path.
> Thanks.
Re: "file not indexed because it was not built" errors [message #149067 is a reply to message #148983] Sat, 16 July 2005 23:45 Go to previous messageGo to next message
I'm using the latest version of CDT (3.0 RC2).
My project is a standard make project, however I'm not using makefiles
(using jam).
Is there something I can do to get rid of the errors?
Thanks.
"jiyul" <plankton@softwitch.net> wrote in message
news:db9md6$kuo$1@news.eclipse.org...
>> Thanks.
Re: "file not indexed because it was not built" errors [message #149514 is a reply to message #149067] Mon, 18 July 2005 11:01 Go to previous messageGo to next message
> (using jam).
Select the errors and right-click. There's an option to delete "C/C++
Markers" or something like that.
Re: "file not indexed because it was not built" errors [message #149518 is a reply to message #149514] Mon, 18 July 2005 13:54 Go to previous messageGo to next message
Originally posted by: chuck_tuffli.sierralogic.com
>> (using jam).
This sucessfully hides the errors, but is there a way to make the
indexing sucessful?
I too have the same problem as the original poster running Eclipse 3.1
with CDT 3.0RC2 on WinXPSP2.
Re: "file not indexed because it was not built" errors [message #149521 is a reply to message #149518] Mon, 18 July 2005 17:07 Go to previous messageGo to next message
>>> makefiles (using jam).
> indexing sucessful?
Oh - sorry - I don't know how to make it stop generating the errors. I
have the same problem. It's not too bad, though, so I'm just ignoring it
and hoping it gets better in a later release.
Re: "file not indexed because it was not built" errors [message #150040 is a reply to message #148756] Tue, 26 July 2005 11:01 Go to previous message
It means that you're using the Full C/C++ Indexer and that you have no build
information. (i.e. no include paths are set up, so there is no way for the
parser to know where to look). You can either enter these paths yourself or
Rebuild project to get some defaults set.
"Yug3sh" <yug3sh@yahoo.com> wrote in message
news:db47ll$ma8$1@news.eclipse.org...
> Thanks.
Previous Topic:unable to call routines from another module
Next Topic:Relative Path to Absolute path problem
Current Time: Thu Nov 27 13:44:06 EST 2025
Powered by FUDForum. Page generated in 0.06174 seconds
