Home » Language IDEs » ServerTools (WTP) » WTP 1.0M9 available for download!
WTP 1.0M9 available for download! [message #148730] Wed, 23 November 2005 17:57 Go to next message
Congradulations to the WTP team! WTP 1.0M9 has just been declared and is
available for download from:
http://download.eclipse.org/webtools/downloads/drops/S-1.0M9 -200511222306/
M9 includes new features such as project facets and documentation as well
as many, many bug fixes. (946 bug fixes since M8!)
WTP 1.0 is right around the corner. Please report any bugs you find in M9
ASAP so we can address the blocking and critical bugs in time for 1.0.
Enjoy!
Re: WTP 1.0M9 available for download! [message #148752 is a reply to message #148730] Wed, 23 November 2005 20:32 Go to previous messageGo to next message
> Enjoy!
Hey, that is great news!
Is there an upgrade path from 0.7/0.7.1 or does one need to do a full
new install?
K<o>
Conficio - we produce animated software manuals that click
Re: WTP 1.0M9 available for download! [message #148861 is a reply to message #148730] Thu, 24 November 2005 04:40 Go to previous messageGo to next message
Originally posted by: zkoppany.gmx.de
Is a complete kit available? I mean that contains eclipse, GEF etc.?
Zsolt
<lmandel@ca.ibm.com> schrieb im Newsbeitrag
news:dm2s4b$28o$2@news.eclipse.org...
> Enjoy!
Re: WTP 1.0M9 - publishing problems [message #148876 is a reply to message #148730] Thu, 24 November 2005 05:39 Go to previous messageGo to next message
I have just upgraded from the last 'I' build to the M9 build, but now have a publishing problem which I did not
have before. The error is ('directory_path' is actually my package hierarchy in the error message):
Publishing failed
Error copying file to {0}: {1}
duplicate entry: /directory_path/vssver.scc
This is stopping me publishing my projects (the error message is actually also duplicated for my J2EE web
library module projects), and also stopping my Tomcat 5.5 localhost server from starting up.
Rus.
Re: WTP 1.0M9 - publishing problems [message #148906 is a reply to message #148876] Thu, 24 November 2005 08:42 Go to previous messageGo to next message
Originally posted by: toby.polley.com
> Publishing failed
I have the same problem with the simple setup: new clean installation of
1.0M9 (with Tomcat 5.5.12).
One Dynamic Web Project 'A' with default configuration referencing (Web
Library dependency) a plain Java Project 'B' with split src/bin dirs.
(Both empty except the default files.)
java.util.zip.ZipException: duplicate entry: META-INF/MANIFEST.MF
at java.util.zip.ZipOutputStream.putNextEntry(ZipOutputStream.j ava:163)
> actually also duplicated for my J2EE web library module projects), and
Same..
Toby
Re: WTP 1.0M9 available for download! [message #148996 is a reply to message #148861] Thu, 24 November 2005 10:50 Go to previous messageGo to next message
> Zsolt
>>Enjoy!
Sorry Zsolt,
the WTP has always been the assembly as it is listed. You have to unzip
all the pieces into the same folder.
Have fun
K<o>
Conficio - http://www.conficio.com - we produce animated software
manuals that click
Re: WTP 1.0M9 available for download! [message #149230 is a reply to message #148861] Sat, 26 November 2005 13:25 Go to previous messageGo to next message
Not for M9. We'll make one available for the WTP 1.0 final release.
Lawrence
Re: WTP 1.0M9 - publishing problems [message #149235 is a reply to message #148906] Sat, 26 November 2005 13:27 Go to previous messageGo to next message
Rus, Toby,
Please open a defect for this problem so it can get resolved in time for
WTP 1.0.
Lawrence
Re: WTP 1.0M9 - publishing problems [message #149253 is a reply to message #148876] Sat, 26 November 2005 18:13 Go to previous messageGo to next message
> have a publishing problem which I did not have before. The error is
> Publishing failed
> Rus.
If you are using J2EE Dependant Modules and the files you see in the
error are from inside those modules.
Watch bugs:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=116964
Believed root cause:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=117956
Darryl
Re: WTP 1.0M9 - publishing problems [message #149525 is a reply to message #149235] Mon, 28 November 2005 07:45 Go to previous messageGo to next message
> for WTP 1.0.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=118221
I am not sure that it is acutally the same issue as yours, Russell. I
discovered that it actually depends on the separate source/output
folders in the dependent Web Library project.
Toby
Re: WTP 1.0M9 - publishing problems - ArrayIndexOutOfBoundsException? [message #149528 is a reply to message #149253] Mon, 28 November 2005 08:38 Go to previous messageGo to next message
I have just upgraded to fresh Eclipse 3.2M3 + WTP 1.0M9, import existing
dynamic project (WTP 0.7), new server (Tomcat 5.0) and publish ->
Error 2005-11-28 14:32:10.203 Could not publish to the server.
java.lang.ArrayIndexOutOfBoundsException
at java.lang.System.arraycopy(Native Method)
org.eclipse.jst.j2ee.internal.deployables.J2EEFlexProjDeploy able.getMembers(J2EEFlexProjDeployable.java:193)
org.eclipse.jst.j2ee.internal.deployables.J2EEFlexProjDeploy able.members(J2EEFlexProjDeployable.java:127)
org.eclipse.wst.server.core.internal.ServerPublishInfo.getDe lta(ServerPublishInfo.java:217)
org.eclipse.wst.server.core.internal.Server.getPublishedReso urceDelta(Server.java:784)
org.eclipse.wst.server.core.model.ServerBehaviourDelegate.ge tPublishedResourceDelta(ServerBehaviourDelegate.java:477)
org.eclipse.jst.server.tomcat.core.internal.TomcatServerBeha viour.getPublishedResourceDelta(TomcatServerBehaviour.java:7 24)
org.eclipse.wst.server.core.model.ServerBehaviourDelegate.pu blish(ServerBehaviourDelegate.java:533)
at org.eclipse.wst.server.core.internal.Server.doPublish(Server .java:704)
at org.eclipse.wst.server.core.internal.Server.publish(Server.j ava:693)
org.eclipse.wst.server.core.internal.PublishServerJob.run(Pu blishServerJob.java:145)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
Server can't start of course... E3.2M3 + WTP 0.7 works perfectly (no
publish problems).
I'm not sure, that it is the same problem.
Martin
Re: WTP 1.0M9 - publishing problems [message #150250 is a reply to message #149235] Thu, 01 December 2005 03:46 Go to previous message
> Rus, Toby,
> WTP 1.0.
> Lawrence
I've dropped back to the previous build for the moment - I have a boss to produce some work for! But I'll see if
I can look into this problem again next week.
Rus.
Previous Topic:Bottom up web service not working with Dates
Next Topic:wtp m9, web services tutorial - error protocol = http host = null
Current Time: Tue Nov 11 05:50:56 EST 2025
Powered by FUDForum. Page generated in 0.05432 seconds
