| Eclipse 3.0M7 (Solaris 8/Motif) crashes after right click [message #148687] |
Mon, 15 March 2004 10:34  |
Originally posted by: Andre.Schneider.eas.iis.fhg.de
Hi all,
I'm using Eclipse 2.1.1 running on Solaris 8 (Motif, KDE 3.1.4)
without any problems.
The new version 3.0M7 (Solaris/Motif) starts fine but when
I click the right mouse button (for context menus) the
IDE crashes with the following error message (see below).
Does anybody know if special X11/Motif patches are
needed for Solaris?
André
[local@serv4:~/eclipse-3.0]>uname -a
SunOS serv4 5.8 Generic_108528-27 sun4u sparc SUNW,Ultra-250
[local@serv4:~/eclipse-3.0]>./eclipse -vm /usr/local/java/bin/java
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : 11 occurred at PC=0xF05B4FC0
Function=XFilterEvent+0x24
Library=/usr/lib/libX11.so.4
Current Java thread:
at org.eclipse.swt.internal.motif.OS.XtDispatchEvent(Native Method)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2155)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1550)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1526)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:265)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:139)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:47)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:257)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:104)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.core.launcher.Main.basicRun(Main.java:279)
at org.eclipse.core.launcher.Main.run(Main.java:742)
at org.eclipse.core.launcher.Main.main(Main.java:581)
Dynamic libraries:
0x10000 /usr/local/java/bin/java
0xff360000 /usr/lib/libthread.so.1
0xff3a0000 /usr/lib/libdl.so.1
0xff200000 /usr/lib/libc.so.1
0xff330000 /usr/platform/SUNW,Ultra-250/lib/libc_psr.so.1
0xfe000000 /tools/usrlocal/java/packages/jdk-1.4.2_04/jre/lib/sparc/cli ent/libjvm.so
0xff2d0000 /usr/lib/libCrun.so.1
0xff1e0000 /usr/lib/libsocket.so.1
0xff100000 /usr/lib/libnsl.so.1
0xff0d0000 /usr/lib/libm.so.1
0xff1c0000 /usr/lib/libsched.so.1
0xff300000 /usr/lib/libw.so.1
0xff090000 /usr/lib/libmp.so.2
0xff060000 /tools/usrlocal/java/packages/jdk-1.4.2_04/jre/lib/sparc/nat ive_threads/libhpi.so
0xff020000 /tools/usrlocal/java/packages/jdk-1.4.2_04/jre/lib/sparc/lib verify.so
0xfe7b0000 /tools/usrlocal/java/packages/jdk-1.4.2_04/jre/lib/sparc/lib java.so
0xfe790000 /tools/usrlocal/java/packages/jdk-1.4.2_04/jre/lib/sparc/lib zip.so
0xfe500000 /usr/lib/locale/en_US.ISO8859-1/en_US.ISO8859-1.so.2
0xfdfd0000 /tools/usrlocal/java/packages/jdk-1.4.2_04/jre/lib/sparc/lib net.so
0xfdfb0000 /tools/usrlocal/java/packages/jdk-1.4.2_04/jre/lib/sparc/lib nio.so
0xfdf90000 /usr/lib/librt.so.1
0xfdee0000 /usr/lib/libaio.so.1
0xfdec0000 /usr/lib/libsendfile.so.1
0xfba90000 /tools/usrlocal/eclipse-3.0/plugins/org.eclipse.swt.motif_3. 0.0/os/solaris/sparc/libswt-motif-3038.so
0xf0680000 /usr/lib/libXm.so.4
0xfb990000 /usr/lib/libXt.so.4
0xf0580000 /usr/lib/libX11.so.4
0xfbbc0000 /usr/openwin/lib/libXp.so.1
0xfbba0000 /usr/lib/libSM.so.6
0xfb8d0000 /usr/lib/libICE.so.6
0xfb8a0000 /usr/lib/libXext.so.0
0xfb880000 /usr/openwin/lib/locale/common/xlibi18n.so.2
0xfb830000 /usr/openwin/lib/locale/common/ximlocal.so.2
0xf9410000 /usr/openwin/lib/locale/iso8859-1/xomEuro.so.2
0xf13e0000 /usr/lib//liblayout.so
Heap at VM Abort:
Heap
def new generation total 2112K, used 1717K [0xf1400000, 0xf1620000, 0xf1b10000)
eden space 2048K, 80% used [0xf1400000, 0xf159d778, 0xf1600000)
from space 64K, 100% used [0xf1600000, 0xf1610000, 0xf1610000)
to space 64K, 0% used [0xf1610000, 0xf1610000, 0xf1620000)
tenured generation total 6656K, used 4352K [0xf1b10000, 0xf2190000, 0xf5400000)
the space 6656K, 65% used [0xf1b10000, 0xf1f50380, 0xf1f50400, 0xf2190000)
compacting perm gen total 11264K, used 11060K [0xf5400000, 0xf5f00000, 0xf9400000)
the space 11264K, 98% used [0xf5400000, 0xf5ecd298, 0xf5ecd400, 0xf5f00000)
Local Time = Mon Mar 15 16:16:21 2004
Elapsed Time = 30
# The exception above was detected in native code outside the VM
# Java VM: Java HotSpot(TM) Client VM (1.4.2_04-b05 mixed mode)
# An error report file has been saved as hs_err_pid19639.log.
# Please refer to the file for further information.
FUDForum. Page generated in 0.02289 seconds
