Newbie Question: Cant find .classpath files [message #148512] |
Thu, 23 October 2003 11:29  |
Originally posted by: mcfaddin.us.ibm.com
I'm new to eclipse, have just downloaded the 2.1.1 SDK, expanded it and
run eclipse.exe. I'm trying to build the helloworld example given in the
online help guide, and have imported the org.eclipse.ui plugins, plus
dependencies.
However, eclipse complains that it cant find these .classpath files for
various of the standard plugins that have been imported, e.g.
Kind Description Resource
Location
Error Unable to read 'org.eclipse.ui/.classpath' file. org.eclipse.ui
Build path
This error message occurs for about a dozen other standard plugins as well.
As I look through the plug in directories that come with eclipse, there
are no such .classpath files anywhere.
I'm sure this is some simple config flag that needs to get flipped
somewhere but I'm lost.
Can someone help me?
Scott McFaddin
Re: Newbie Question: Cant find .classpath files [message #148713 is a reply to message #148512] |
Thu, 23 October 2003 15:28  |
BTW, For those reading this,
Rich Kulp and I investigated this, and it turns out the problem is that
Eclipse 2.1.1 (which I am running) does not work with the 1.4 JRE -- you
need the 1.3 one!
Many many thanks to Rich for locating this problem!!
Scott McFaddin
> dependencies.
> Location
> Build path
> Scott McFaddin
FUDForum. Page generated in 0.02958 seconds
