Home » Archived » BIRT » Using Two Data Sources in a Chart
Using Two Data Sources in a Chart [message #148466] Mon, 27 March 2006 09:44 Go to next message
Originally posted by: sarah.dewar.farrow.com
Hello all,
I need to pull data from two separate systems but I have to display this
data using one Bar Chart.
Could someone please tell me if it is possible to use two data sources to
generate one chart or point me to the proper documentation.
Your help is appreciated,
Sarah
Re: Using Two Data Sources in a Chart [message #148936 is a reply to message #148466] Tue, 28 March 2006 08:39 Go to previous messageGo to next message
No, the chart can only access one dataset. I would suggest to show two
different charts. Regardless of that, how do you combine the data from two
data sources, the number of rows returned could be different?
David
"Sarah Dewar" <sarah.dewar@farrow.com> wrote in message
news:82c680b49198a5ac70ab960b152769c8$1@www.eclipse.org...
> Hello all,
> Sarah
Re: Using Two Data Sources in a Chart [message #148980 is a reply to message #148936] Tue, 28 March 2006 09:07 Go to previous message
Originally posted by: Sarah.Dewar.farrow.com
This is a multipart message in MIME format.
--=_alternative 004D88548525713F_=
Content-Type: text/plain; charset="US-ASCII"
I figured out a way to do it with a scripted data source.
All I was trying to do was perform some simple queries that would return
the result of a select count(*) from ......... and display them in a
chart.
Sarah
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">I figured out a way to do it with a
scripted data source.</font>
<br>
<br><font size=2 face="sans-serif">All I was trying to do was perform some
simple queries that would return the result of a select count(*) from .........
and display them in a chart.</font>
<br>
<br><font size=2 face="sans-serif">Thanks,</font>
<br><font size=2 face="sans-serif">Sarah</font>
--=_alternative 004D88548525713F_=--
Previous Topic:difference between parameters and filters
Next Topic:Reports in Web page using PHP
Current Time: Mon Nov 17 13:41:25 EST 2025
Powered by FUDForum. Page generated in 0.04204 seconds
