Home » Archived » BIRT » Drivers jdbc SQL Server
Drivers jdbc SQL Server [message #148400] Mon, 27 March 2006 06:41 Go to next message
I try to add a jdbc driver for SQL Server to the "JDBC data sources". I
click on "manage the driver" and add the .jar (sqljdbc.jar). The driver
appears in the list of jar files but nothing in the tab "driver" ! Why ?
How can I have the jdbc driver for SQL server with BIRT ?
Thank you.
Re: Drivers jdbc SQL Server [message #148408 is a reply to message #148400] Mon, 27 March 2006 06:53 Go to previous messageGo to next message
It is good. After 10 attempts. It works. The problem seems appears cause
of my Virtual PC ...
Re: Drivers jdbc SQL Server [message #148432 is a reply to message #148408] Mon, 27 March 2006 08:18 Go to previous messageGo to next message
The driver has correctly added but I don't manage to establish a
connection. Every time I try, a timeout ...
My database is correct, I manage to access with odbc.
My url is : jdbc:sqlserver://localhost\\Northwind (the user and password
are in others fields)
Why did I fail ?
Re: Drivers jdbc SQL Server [message #148519 is a reply to message #148432] Mon, 27 March 2006 10:42 Go to previous messageGo to next message
> Why did I fail ?
Here is my url:
jdbc:sqlserver://data-server-1:1433;DatabaseName=MedBase
Probably you will see difference :)
Re: Drivers jdbc SQL Server [message #148828 is a reply to message #148519] Tue, 28 March 2006 05:04 Go to previous message
Yes, it is good.
Tks
PS : the authentification must be done by Sql Server & Windows but not
only Windows ... It was my problem ...
Previous Topic:Unable to set barcode-font in birt-rcp-report-designer 2.0.0
Next Topic:print
Current Time: Wed Jun 04 15:35:27 EDT 2025
Powered by FUDForum. Page generated in 0.24576 seconds
