Home » Eclipse Projects » Eclipse Platform » How to lunch Eclipse programmatically (from Java app.)
How to lunch Eclipse programmatically (from Java app.) [message #148385] Thu, 23 October 2003 08:55 Go to next message
Originally posted by: _mcbear.mail.ru
Hi, all
Dummy question but could you help me please. Which Main class method I
should invoke and with which params?
McBear
Re: How to lunch Eclipse programmatically (from Java app.) [message #148399 is a reply to message #148385] Thu, 23 October 2003 09:37 Go to previous messageGo to next message
You should programmaticlly use a launch configuration to launch Eclipse -
specifically a "runtime workbench" launch configuration. See these articles
for tips on using launch configs programmatically.
http://www.eclipse.org/articles/Article-Java-launch/launchin g-java.html
http://www.eclipse.org/articles/Article-Launch-Framework/lau nch.html
Darin
"mcBear" <_mcbear@mail.ru> wrote in message news:bn8j3v$a73$1@eclipse.org...
> Hi, all
> Regards
> McBear
Re: How to lunch Eclipse programmatically (from Java app.) [message #148645 is a reply to message #148385] Thu, 23 October 2003 13:49 Go to previous messageGo to next message
Originally posted by: John_Arthorne.oti.com_
Not sure if you're asking how to programatically launch eclipse from
within eclipse, or from a shell script or other application. The entry
point is org.eclipse.core.launcher.Main in startup.jar. Use the same
parameters that you would pass to the eclipse executable (of course -vm
parameter is not needed). If it is the first invocation on a given
-data location, it will exit after completing the install and you will
have to launch a second time.
mcBear wrote:
> Hi, all
> Regards
> McBear
Re: How to lunch Eclipse programmatically (from Java app.) [message #148968 is a reply to message #148645] Fri, 24 October 2003 03:36 Go to previous messageGo to next message
Hi, John
Thanks a lot. It was that I need. After I posted my question I found that
class I should instanciate, but I didn't know in which jar it is placed.
McBear
> mcBear wrote:
> > Hi, all
> > Regards
> > McBear
Re: How to lunch Eclipse programmatically (from Java app.) [message #148989 is a reply to message #148645] Fri, 24 October 2003 05:23 Go to previous messageGo to next message
Hi, John again
I have got a new trouble. I created class:
-- cut --
import org.eclipse.core.launcher.Main;
class qqq {
public static void main( String[] argv ) {
Main.main( "-os linux -ws gtk" );
-- end cut --
after then I compiled it I tried to run it using command:
java -classpath "<eclipse>/org.eclipse.platform/startup.jar:." qqq
I got nothing. Eclipse doesn't start. What am I doing wrong?! Could you
correct me, please? If you can
McBear
> mcBear wrote:
> > Hi, all
> > Regards
> > McBear
Re: How to lunch Eclipse programmatically (from Java app.) [message #149148 is a reply to message #148989] Fri, 24 October 2003 13:09 Go to previous message
Try launching from within a debugger to see what's happening. Perhaps
an exception is being thrown.
mcBear wrote:
> Hi, John again
> -- cut --
> class qqq {
> -- end cut --
> Regards
> McBear
>>mcBear wrote:
>>>Hi, all
>>>Regards
>>>McBear
Previous Topic:Adding Squiggle lines to text
Next Topic:Question about Feature Updates
Current Time: Thu Jul 17 17:10:47 EDT 2025
Powered by FUDForum. Page generated in 0.05443 seconds
