Home » Language IDEs » Java Development Tools (JDT) » What's building secret of Eclipse
What's building secret of Eclipse [message #148371] Fri, 12 March 2004 14:23 Go to next message
Originally posted by: mfan.simplicti.com
I used to work on java project with gvim combined ant. I write a
customized build.xml to control cimpiling. Now I switched to eclipse.jdt.
However, I cannot find the point where I can import my original build.xml
into the project for building. How can I build the my project in eclipse
with my original build.xml? Thank you.
Re: What's building secret of Eclipse [message #148451 is a reply to message #148371] Fri, 12 March 2004 21:46 Go to previous messageGo to next message
You will need to create a builder for your project that will trigger an Ant
build using your build.xml (and likely disable the Java builder).
See the Properties dialog for your project.
The Builders tab is where you want to work
HTH
Darins
"Max" <mfan@simplicti.com> wrote in message news:c2t2n1$tvi$1@eclipse.org...
Re: What's building secret of Eclipse [message #148607 is a reply to message #148451] Sun, 14 March 2004 22:23 Go to previous messageGo to next message
Hmm. I created a new builder using ant. Now when I "Rebuild the project",
this builder is invoked. However, I found that in the tasks view, the
display of "tasks" page and the "console" page is inconsistent. Looks like
"console" page dislayed the ant-builder result, while the "tasks"
displayed the default builder result. Can I also force the "tasks" page
reflects the ant-builder result? Thank you.
> HTH
> Darins
Re: What's building secret of Eclipse [message #148616 is a reply to message #148607] Sun, 14 March 2004 22:59 Go to previous message
No
Darins
"Max" <mfan@simplicti.com> wrote in message news:c337jj$c3c$1@eclipse.org...
Ant
> > HTH
> > Darins
eclipse.jdt.
build.xml
eclipse
Previous Topic:Eclipse console colour configuration
Next Topic:Is automatic variable usage highlight possible ?
Current Time: Sat Jul 26 09:55:07 EDT 2025
Powered by FUDForum. Page generated in 0.30648 seconds
