Home » Language IDEs » ServerTools (WTP) » formatting a jsp but skipping the undo stack
formatting a jsp but skipping the undo stack [message #148370] Tue, 22 November 2005 16:35 Go to next message
I am inserting some text into a jsp page, then formatting the newly
inserted text by calling IStructuredFormatProcessor.formatDocument() for
the range of the new text.
This all works fine, the only problem is that the format operations all go
onto the undo stack.
So after the insert, if you press ctrl-Z, you first must cycle through
undoing all of the format operations before you can actually undo the
original insertion.
Is there a way to make the format operations skip the undo stack?
Scott
Re: formatting a jsp but skipping the undo stack [message #148691 is a reply to message #148370] Wed, 23 November 2005 16:25 Go to previous messageGo to next message
> original insertion.
Not skip, no, but you can accumulate it into one big undoable
operations. If you look at the
StructuredTextViewer.doOperation(int) method, you'll see that the
format handling wraps the formatting between a beingRecording and
endRecording method. You'd need to do something similar around the
inserting and formatting of your text.
- Nitin
Re: formatting a jsp but skipping the undo stack [message #148699 is a reply to message #148691] Wed, 23 November 2005 16:47 Go to previous message
Great! I will try that.
Thanks *very* much for your response.
Previous Topic:Status of M9 and opportunity for early testers: M9 planned for 11/23
Next Topic:JBOSS3.2.5 server definition
Current Time: Sat Jul 26 15:57:46 EDT 2025
Powered by FUDForum. Page generated in 0.26433 seconds
