Home » Language IDEs » C / C++ IDE (CDT) » #error & indexer
#error & indexer [message #148315] Thu, 07 July 2005 01:48 Go to next message
I have some problems with the indexer that seem to be related to #error
statements in header files.
eg
#error "This is a C++ header file; it requires C++ to compile."
CDT 3.0RC1, Eclipse 3.1
Is there a place I can configure something or is this a bug?
Cheers, Patrick
Re: #error & indexer [message #148324 is a reply to message #148315] Thu, 07 July 2005 03:10 Go to previous messageGo to next message
> eg
What is #error? It's not a C++ keyword, that's for sure. Some
proprietary language enhancement I guess, probably MS?
Since it's not part of the language, I wouldn't consider it a bug that
CDT doesn't recognize it.
Matthias
Re: #error & indexer [message #148338 is a reply to message #148324] Thu, 07 July 2005 06:00 Go to previous messageGo to next message
From http://library.n0i.net/programming/c/cp-iso/cpp.html
A preprocessing directive of the form
# error pp-tokensopt new-line
causes the implementation to produce a diagnostic message that includes
the specified sequence of preprocessing tokens, and renders the program
ill-formed.
I'm kind of hoping it will be supported cause it appears to be nobbling
the indexer.
>> #error statements in header files.
>> eg
> Matthias
Re: #error & indexer [message #148384 is a reply to message #148338] Thu, 07 July 2005 13:41 Go to previous messageGo to next message
> ill-formed.
Oh well, it looks like it is indeed part of the standard. Sorry for the
noise.
Re: #error & indexer [message #148424 is a reply to message #148315] Fri, 08 July 2005 02:38 Go to previous messageGo to next message
I have filed a bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=103108
> eg
> Cheers, Patrick
Re: #error & indexer [message #148454 is a reply to message #148338] Fri, 08 July 2005 10:40 Go to previous messageGo to next message
"Patrick MacQuillan" <patrick.macquillan@motorola.com> wrote in message
news:daiubt$uan$1@news.eclipse.org...
> ill-formed.
The indexer is doing exactly what it is supposed to do: producing a
diagnostic message. Everything else is still being indexed.
To get rid of the error, consider whatever #ifdef guard surrounds it and
make sure your predefined paths and symbols are setup properly in your
project properties.
-Andrew
Re: #error & indexer [message #148534 is a reply to message #148454] Sun, 10 July 2005 21:21 Go to previous message
Thanks Andrew, my bad - that's exactly what it was - a symbol had not
been defined.
>>ill-formed.
> project properties.
> -Andrew
Previous Topic:SCons support
Next Topic:GDB remote debugging
Current Time: Fri Nov 07 12:16:34 EST 2025
Powered by FUDForum. Page generated in 0.04320 seconds
