Home » Eclipse Projects » GEF » Direct edit out of sight
Direct edit out of sight [message #148306] Mon, 23 August 2004 03:30 Go to next message
Hi all,
In Logic editor there is a wrong behaviour during direct editor:
- open a Logic diagram
- if there is no scrollbars add an item at the bottom so that the
scrollbar appears
- add a label at the top and edit his value
- during the edition scroll down so that the label disappear
- move back: the cell editor will no more be over the label
Bugzilla #19470 is very similar but should be fixed since 2002.
Is this an erron in Logic or a bug?
I am using Eclipse 3.0 with GEF 3.0 on Win 2000
Thanks in advance for any help
Roberto
Re: Direct edit out of sight [message #148344 is a reply to message #148306] Mon, 23 August 2004 15:42 Go to previous messageGo to next message
I think this is an win32/SWT issue. Can you reproduce on Motif ot GTK?
"Roberto Genini" <roberto.genini@icimsi.ch> wrote in message
news:opsc6cgntl71gv6x@news.eclipse.org...
> Hi all,
> scrollbar appears
> Roberto
Re: Direct edit out of sight [message #148389 is a reply to message #148344] Tue, 24 August 2004 03:01 Go to previous messageGo to next message
Sorry but I only have a win32 installation :-(
>> Hi all,
>> scrollbar appears
>> Roberto
Using M2, Opera's revolutionary e-mail client: http://www.opera.com/m2/
Re: Direct edit out of sight [message #148426 is a reply to message #148389] Tue, 24 August 2004 10:22 Go to previous messageGo to next message
Try searching for a bugzilla I opened against SWT. If a Text control has
focus on a scrollable composite, the text control cannot be scrolled out of
view.
news:opsc75s0s471gv6x@news.eclipse.org...
> >> Hi all,
> >> scrollbar appears
> >> Roberto
Re: Direct edit out of sight [message #148455 is a reply to message #148426] Tue, 24 August 2004 11:59 Go to previous messageGo to next message
Can't find the bugzilla, sorry.
Can you give more info?
(I am leaving now)
> of
> view.
>> GTK?
>> >> Hi all,
>> >> scrollbar appears
>> >> Roberto
Re: Direct edit out of sight [message #148612 is a reply to message #148455] Wed, 25 August 2004 10:32 Go to previous messageGo to next message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=41111
Yup, you never would have found it. You would have had to search for me as
the reporter *OR* CC'ed on the bugzilla, since often people open a GEF bug
and then I reroute to SWT, or someone on my team opens the bug for me.
Another hint is that I try to mark cross-platform issues with
"[portability]" in the Summary. Still not sure if this is your issue or
not.
news:opsc8up2vx71gv6x@news.eclipse.org...
> Thanks
> (I am leaving now)
Re: Direct edit out of sight [message #148718 is a reply to message #148612] Thu, 26 August 2004 09:13 Go to previous messageGo to next message
Should I open a new bugzilla referencing the old one?
> as
> bug
> not.
Re: Direct edit out of sight [message #149547 is a reply to message #148612] Wed, 01 September 2004 08:54 Go to previous message
Have you found out if this is a bug?
> as
> bug
> not.
>> Thanks
>> (I am leaving now)
Previous Topic:KeyListeners in ClassDiagram Using Draw2d
Next Topic:layers issue
Current Time: Mon Sep 22 15:32:00 EDT 2025
Powered by FUDForum. Page generated in 0.05759 seconds
