| Re: Is it possible to create a semi-transparent figure? [message #148220 is a reply to message #148215] |
Thu, 19 August 2004 16:32  |
A figure is nothing more than paint calls. None of the painting API
supports transparency. However, an Image may contain an alpha mask which
may be 8-bit depth. So you can fake it with Images, but it's very slow and
memory intensive if you need to do anything large.
"Dolev Dotan" <dolevd@cs.technion.ac.il> wrote in message
news:cg319b$dan$1@eclipse.org...
> Well, the subject line says it all... But in other words, can I set a
figure
> to be, say, 30% transparent?
> Thanks
> Dolev
FUDForum. Page generated in 0.03173 seconds
