Home » Eclipse Projects » GEF » Is it possible to create a semi-transparent figure?
Is it possible to create a semi-transparent figure? [message #148215] Thu, 19 August 2004 17:07
Well, the subject line says it all... But in other words, can I set a figure
to be, say, 30% transparent?
Dolev
Re: Is it possible to create a semi-transparent figure? [message #148220 is a reply to message #148215] Thu, 19 August 2004 16:32 Go to previous message
A figure is nothing more than paint calls. None of the painting API
supports transparency. However, an Image may contain an alpha mask which
may be 8-bit depth. So you can fake it with Images, but it's very slow and
memory intensive if you need to do anything large.
"Dolev Dotan" <dolevd@cs.technion.ac.il> wrote in message
news:cg319b$dan$1@eclipse.org...
figure
> Thanks
> Dolev
Previous Topic:How to make a connector touch the shape
Next Topic:Change cursor when moving tree item to different parent not allowed
Current Time: Mon Sep 01 05:19:00 EDT 2025
Powered by FUDForum. Page generated in 0.03054 seconds
