Home » Language IDEs » Java Development Tools (JDT) » Automatic generation of Jar and Javadoc
Automatic generation of Jar and Javadoc [message #148179] Thu, 11 March 2004 10:51 Go to next message
Originally posted by: news-reply-200403.iclipse.org
Is there a way to set options allowing the following:
- automatically create a new Jar-Archive upon every build or rebuild
- automatically create a new Jar-Archive upon one or two clicks
- automatically generate the Javadoc documentation upon every build
or rebuild
- automatically generate the Javadoc documentation upon one or two
clicks
Igor
Re: Automatic generation of Jar and Javadoc [message #148183 is a reply to message #148179] Thu, 11 March 2004 11:49 Go to previous messageGo to next message
> or rebuild
> clicks
I think an ant script will do it. But maybe there is another way.
Martin (Kersten)
Re: Automatic generation of Jar and Javadoc [message #148216 is a reply to message #148183] Thu, 11 March 2004 17:36 Go to previous messageGo to next message
>>or rebuild
>>clicks
It would be nice if Eclipse could be set to build a jar file as the
default output
Re: Automatic generation of Jar and Javadoc [message #148232 is a reply to message #148216] Thu, 11 March 2004 18:18 Go to previous messageGo to next message
"Peter" <kaffiene@xtra.NOcoSPAM.nzPLEASE> wrote in message
news:c2qpef$ad4$1@eclipse.org...
> >>or rebuild
> >>clicks
> default output
Create an External tool builder that executes an Ant build.
You can set the tool builder to be triggered for any type of build and/or
set a working set of resources that must be changed to for the Ant build to
be triggered.
External tool builders can be created using:
Right click on a project
Select Properties
Select Builders
Click New
HTH
Darins
Re: Automatic generation of Jar and Javadoc [message #148256 is a reply to message #148232] Thu, 11 March 2004 21:49 Go to previous message
>>>>or rebuild
>>>>clicks
>>default output
> be triggered.
> Select Properties
> Select Builders
> Click New
Yeah I know that. It would still be nice to be able to have a jar output
target without having to use ant. Its the most common way to distribute
java code, so it does strike me as odd that you can't build a jar
directly (I like using Ant personally, but I imagine some people would
rather avoid the whole malke file style approach - especially newbies)
Peter.
Previous Topic:SORRY for the repeated messages!
Next Topic:show HTML pages inside Eclipse
Current Time: Wed Nov 05 00:35:15 EST 2025
Powered by FUDForum. Page generated in 0.04126 seconds
