| Debug Web Service [message #148145] |
Mon, 21 November 2005 08:55 |
I have created a web service using Eclipse 3.1.1. I deployed the web
service to a Tomcat server and all was running well. I then needed to go
back and edit the web service. I make my changes in the Eclipse 3.1.1
environment, select debug mode but the flow by passes all my new code. If
I go up and peform a Clean build on the project it picks up my new code.
However, before I deployed the Web Service I did not have to do this and
it is a bit cumbersome to have to perform a clean build to test some code
changes. Especially if you want to make the code changes as you are
debuging. I would appreciate any help on this.
Ben
FUDForum. Page generated in 0.03632 seconds
