Home » Modeling » GMF (Graphical Modeling Framework) » How can I use my AutomaticRouter?
How can I use my AutomaticRouter? [message #148006] Mon, 27 August 2007 23:29 Go to next message
Dear all,
The only AutomaticRouter realized in gmf is FanRouter,but now I want
use another AutomaticRouter to give more functions such as when two line
are metches(even when their sources and ends are not the same), the
algorithom can also identified, and can give some nice solutions.
But currently I have a problem, I noticed that the defalut
connectionLayer registered is ConnectionLayerEx,when get ObliqueRouter
from the layer, it returns the FanRouter.
I don't know how can I register my ConnectionLayer, or whether if there
are other nice ways to achieve that goal. Please give me some
suggestions about this.
Thank you!
Re: How can I use my AutomaticRouter? [message #148120 is a reply to message #148006] Tue, 28 August 2007 16:59 Go to previous messageGo to next message
Originally posted by: vinsarwate.rediffmail.com
Not sure but there is "installRouter" method available in
ConnectionEditPart. Is it possible to use this method for having custom
router ?
Vinay
Re: How can I use my AutomaticRouter? [message #148122 is a reply to message #148120] Tue, 28 August 2007 20:42 Go to previous messageGo to next message
Thank you Vinay,
The installRouter() method needs the support of the ConnectionLayer,
which applied getXXXRouter() method. But the default ConnectionLayer is
the ConnectionLayerEx, I have no idear about how to change it. I can
override the methods in my own way, but I don't know how the new
ConnectionLayerEx be used.
Could any one give me some more help?
Nemo
Vinay 写道:
> router ?
> Vinay
Re: How can I use my AutomaticRouter? [message #149442 is a reply to message #148122] Thu, 06 September 2007 11:44 Go to previous message
Nemo,
Is this the same issue?
https://bugs.eclipse.org/bugs/show_bug.cgi?id=149861
- Cherie
nemo wrote:
> Thank you Vinay,
> Nemo
> Vinay 写道:
>> custom router ?
>> Thanks,
>> Vinay
Previous Topic:Change connection ends programatically
Next Topic:How to create edit part for specialized model object
Current Time: Fri Nov 07 02:44:05 EST 2025
Powered by FUDForum. Page generated in 0.33195 seconds
