Home » Modeling » GMF (Graphical Modeling Framework) » Compartments in 2.0
Compartments in 2.0 [message #147971] Mon, 27 August 2007 12:27 Go to next message
I'm trying to upgrade to GMF 2.0. I just want to get everything I have in
my older version of GMF working in 2.0. Starting from scratch, same
annotated java etc, I've tried to build a new editor.
I've tried a few times and I keep getting the same one error in same place
in the compartments, in Node3EditPart.java:
The method getFigureNodeNameFigure() is undefined for the type
Node3EditPart.NodeNodeFigure
There must be something I'm missing, a new compartment setting or
something.
I haven't upgraded since February so I'd be on M4 or M5. Possibly the
structure for creating a compartment has changed? Briefly:
-Node B is contained by node A in model (from annotated java)
-Add Compartment to gmfgraph
-Add Compartment mapping to A node mapping
-Add Child Reference to A node mapping (which includes B node mapping)
I've used all the same settings etc as before but I keep getting the same
error. There are a few new settings possibly it's one of these?
Gaff
Re: Compartments in 2.0 [message #149124 is a reply to message #147971] Wed, 05 September 2007 12:46 Go to previous messageGo to next message
Hi would someone be able to answer this for me?
Gaff
Re: Compartments in 2.0 [message #149776 is a reply to message #147971] Mon, 10 September 2007 12:22 Go to previous message
Hello Gaff,
I suppose you have problems with defining inner lable using updated GMFGRAPH
model. I suggest you to have a look on org.eclipse.gmf.graphdef\models\basic.gmfgraph
- this model contains NamedNodeRectangle description with inner label in it.
Alex Shatalin
Previous Topic:Accessor property for Compartment
Next Topic:Removing standard tools
Current Time: Sat Jul 12 02:24:35 EDT 2025
Powered by FUDForum. Page generated in 0.03811 seconds
