Home » Eclipse Projects » GEF » editor with no palette..Possible?
editor with no palette..Possible? [message #147968] Tue, 17 August 2004 16:00 Go to next message
I have a GEF editor that now has just two palette entries, the selection
tool and the connection tool.
To save space I want to move these two tools to the toolbar, or the like.
This will allow me to remove th palette compeletely.
Can this be done...? For example make a button press choose the selection
tool.?
Mark.
Re: editor with no palette..Possible? [message #147977 is a reply to message #147968] Tue, 17 August 2004 17:10 Go to previous messageGo to next message
Originally posted by: gaslade.yahoo.com
I did this once, so, yes, it is possible. But I ditched it as my editor
looked way too different to all the other IBM GEF based graphical editors.
Another option you might consider is instead of having the tools on the
toolbar, having then as part of your context pop-up menu.
Guy
> tool.?
> Mark.
Re: editor with no palette..Possible? [message #147987 is a reply to message #147968] Wed, 18 August 2004 02:25 Go to previous messageGo to next message
Originally posted by: eostroukhov.hotmail.com
Sure. Take a look at GraphicalEditor class.
"mark" <mark.geib@echostar.com> wrote in message
news:cfto5c$4et$1@eclipse.org...
> tool.?
> Mark.
Re: editor with no palette..Possible? [message #148295 is a reply to message #147987] Sat, 21 August 2004 11:16 Go to previous message
Originally posted by: gupolet.ulb.ac.be
What about a GraphicalEditorWithFlyoutPalette ?
The palette docks itself automatically so it only takes a few pixels from
the view. It also allows you to lock the dockstate or to switch the palette
in a independent view.
The class is quite easy to implement and all you have to do is provide a
regular palette like before, GEF will handle all the troubles:-)
Guillaume
"Eugene Ostroukhov" <eostroukhov@hotmail.com> a
Previous Topic:MultiLineLabel parent Composite from Draw2D Panel?
Next Topic:coordinate mapping
Current Time: Fri Nov 07 17:12:19 EST 2025
Powered by FUDForum. Page generated in 0.04022 seconds
