Home » Archived » BIRT » Remove data set access for an extended item
Remove data set access for an extended item [message #147897] Fri, 24 March 2006 11:11
I'm developping a new report item using the extensions Birt provides. I
somehow succeeeded in creating my item, but I get the following problem:
"The extendedItem must be able to access one data set".
How can I remove that problem since I don't need to access any data set
with that report item?
For information, I extended the reportitemUI, reportitemPresentation and
reportitemModel.
For reportitemPresentation, I extended ReportItemPresentationBase class
and I set my output as: OUTPUT_AS_HTML_TEXT and I wrote my code in
onRowSets method.
Previous Topic:Birt and Tree
Next Topic:Can't connect to X11 window server using ':0.0' as the value of the DISPLAY variable !?!
Current Time: Fri Nov 07 01:48:37 EST 2025
Powered by FUDForum. Page generated in 0.02832 seconds
