Home » Archived » BIRT » problem with output in pdf
problem with output in pdf [message #147795] Fri, 24 March 2006 06:21 Go to next message
Originally posted by: pascal.rondeu.laposte.net
I'm using Birt-viewer 2.0 under tomacat.
All reports run fine (I use the run option) but the pdf options
(__format=pdf) generate an error message : Error happened while running
the report in the output window.
Do you have any idea where to look when such error occurs?
Pascal
Re: problem with output in pdf [message #147836 is a reply to message #147795] Fri, 24 March 2006 07:39 Go to previous messageGo to next message
The problem seems to come from the lib itext-1.4.jar is which not taken
into consideration.
It is currently located in C:\Program Files\Apache Group\Tomcat
4.1\webapps\birt-viewer\plugins\org.eclipse.birt.report.engi ne.emitter.pdf\lib
but this does not seems to work out.
If I copy it the web-inf/lib and restartTomcat, I get an output which is
badly interpreted by IE6.
Pascal
Re: problem with output in pdf [message #147867 is a reply to message #147836] Fri, 24 March 2006 08:54 Go to previous messageGo to next message
solution:
The problem comes from itext version : I used 1.4 instead of 1.3.
Apparently birt viewer only does not work with 1.4
Re: problem with output in pdf [message #147988 is a reply to message #147867] Fri, 24 March 2006 18:14 Go to previous message
It does work if you change the value in the plugin.xml file to state the
correct JAR file.
Previous Topic:Error when using Inline in a list.
Next Topic:POJO Data Source / Session Object Access - Example Available
Current Time: Mon Jul 21 21:14:34 EDT 2025
Powered by FUDForum. Page generated in 0.37401 seconds
