Home » Language IDEs » C / C++ IDE (CDT) » Newbie: problem running C++ application
Newbie: problem running C++ application [message #147748] Wed, 29 June 2005 11:00 Go to next message
Originally posted by: pschmitt.students.depaul.edu
I made a simple Hello-World application using Eclipse + CDT and standard
make. My program compiles just fine. If I open a console, I can run my
program without problem.
In Eclipse, I:
1. goto Run -> Run...
2. Select C/C++ Local Application
3. New
4. Set application name and appropriate project
5. Click apply
6. the "Run" button is grayed out! I can't execute my program!
I am running Linux, Eclipse 3.1 SDK and I downloaded the CDT runtime & SDK.
Also... I am new to eclipse. I was surprised how slow the website has
been today & yesterday. Was a major update just released?
Thanks!
Pete
Re: Newbie: problem running C++ application [message #147764 is a reply to message #147748] Wed, 29 June 2005 12:49 Go to previous messageGo to next message
Originally posted by: bandrews.nospam_bphnx.com
Did you leave a required field empty or it's invalid? There should be a
message in the upper left corner if something is wrong with your
configuration.
3.1 GA was just released. I think everyone is flocking to the web site.
I have also noticed it is very slow.
-Barry
Peter Schmitt wrote:
> In Eclipse, I:
> 3. New
> 5. Click apply
> Thanks!
> Pete
Re: Newbie: problem running C++ application [message #147812 is a reply to message #147764] Thu, 30 June 2005 10:37 Go to previous messageGo to next message
Originally posted by: simon.ou.edu
Hi Barry...
You mention 3.1 GA is available, but I do not see it. Would this be the
same as I200506291405 ? Thanks.
Regards...
Miguel.
> configuration.
> -Barry
Re: Newbie: problem running C++ application [message #147820 is a reply to message #147812] Thu, 30 June 2005 12:00 Go to previous messageGo to next message
It's here:
http://download.eclipse.org/eclipse/downloads/drops/R-3.1-20 0506271435/index.php
Miguel Simon wrote:
> Hi Barry...
> Regards...
> Miguel.
>> a message in the upper left corner if something is wrong with your
>> configuration.
>> site. I have also noticed it is very slow.
>> -Barry
Re: Newbie: problem running C++ application [message #150908 is a reply to message #147748] Fri, 05 August 2005 09:20 Go to previous message
Originally posted by: sunil_pict.yahoo.com
I thinnk u are also facing same problen as that to me.
So It's because your .exe file not might be getting created that's why ur
run button is greyed out.
I don't know how to solve problem.because as per help ur .exe should be
made after saving appli.
please ,inform me if u can sort out using any document or help.
Bye,(sunil_pict@yahoo.com)
Previous Topic:gdb: unrecognized option -i (solaris eclipse)
Next Topic:Query:How to create C/C++ application.
Current Time: Sun Nov 09 02:56:43 EST 2025
Powered by FUDForum. Page generated in 0.03535 seconds
