Home » Language IDEs » ServerTools (WTP) » jsp 2.0 tag files.
jsp 2.0 tag files. [message #147550] Thu, 17 November 2005 12:44 Go to next message
Originally posted by: mark.markgordon.org
I have tags written using the jsp 2.0 .tag files.
They are included in my jsp file using:
<%@ taglib tagdir="/WEB-INF/tags/html" prefix="h" %>
When I use a tag defined in this directory I get an Unknow tag warning.
This causes a problem because I have so many unknow tag warnings that I
can't edit the file because it is so slow.
How can i get the web tools to see these tags?
Mark
Re: jsp 2.0 tag files. [message #147567 is a reply to message #147550] Thu, 17 November 2005 14:49 Go to previous messageGo to next message
Currently you can't, and there simply isn't enough time to put such
a large addition into WTP 1.0. Please keep an eye on bug 97407 for
when this is implemented.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=97407
- Nitin
Re: jsp 2.0 tag files. [message #147583 is a reply to message #147567] Thu, 17 November 2005 16:41 Go to previous message
Then is there an easy way to turn off the warnings for JSP? If so how
would I do this?
I also get some errors of undefined variables that are defined in useBeans
of included files.
<%@ include file="/include/applicationtop.jsp" %>
Also if a useBean is used to create an object in your session but it is
only used via el ${xxxx.xxx} then you are warned that it is never used.
I have so many warnings and errors that I can't edit my files :-) It
seems to only be a problem with larger jsp files. Even though they
compile and run fine.
The large amount of warnings come from use of JSP 2.0
-Mark
Previous Topic:Where can I open the "design view" for xml-file?
Next Topic:a glimpse at I200511162235
Current Time: Wed Nov 05 04:00:05 EST 2025
Powered by FUDForum. Page generated in 0.04732 seconds
