Own calculations [message #147490] |
Thu, 23 March 2006 09:36  |
Originally posted by: r.budner.abg.com.pl
I would like to calculate total sum of the whole report and place it in
the outer table's footer row. The data I want to sum are in inner table.
To achieve this, I created global variable and I want to calculate sum
myself in onCreate for each inner table's row:
total_sum = total_sum + ...
I don't know what to add.
total_sum = total_sum + row["myColumn"] - doesn't work
this.getRowData().getExpressionValue("row[myColumn]") - doesn't work
neither because getExpressionValue() doesn't return direct dataset's row
value, but it returns expression value instead. In this case this
expression is 'row["myColumn"] + " hrs' so it obviously cannot be used
in addition.
I'm then seeking the method to reference the dataset's pure value for
current row but with no luck so far.
Help
Re: Own calculations [message #149341 is a reply to message #149262] |
Wed, 29 March 2006 20:46   |
Robbo,
I got your code, but I did not see anyplace where you had script. So
what I did is created a simple example running against the classic
models db that is distributed with BIRT. I have attached the report in
clear text at the bottom of this post.
The places you want to look at the code are:
- In the initialize method of the report object
I create a logger and two global functions
one for logging
one for adding up a total
- In the control that contains the inner value, I add each row item
value through the global function
- In the after of the entire report I display the global variable of
all the totals.
I am not quite sure why I had to use the global function, but it would
appear something was happening if I tried to access the global variable
directly (no I am not sure why). You will not want to have the logging
in there, I just put it in to prove to myself that the code was working
the way I expected it to.
Hope this helps,
Scott
Here is the report code:
<!-- Written by Eclipse BIRT 2.0 -->
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3" id="1">
<property name="createdBy">Eclipse BIRT Designer Version 2.0.0
Build <20060123-1141></property>
<property name="units">in</property>
<property
name="comments"> ************************************************************ **************
* Copyright (c) 2004, 2005 Innovent Solutions, Inc.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* Scott Rosenbaum
* Innovent Solutions Inc. - initial implementation
************************************************************ ************* </property>
<method name="initialize"><![CDATA[/* INTIALIZE THE LOGGER WITH A
FILE BASED LOGGER
importPackage(Packages.java.util.logging);
var fileHandler = new FileHandler("birt_log.log", false);
var rootLogger = Logger.getLogger("");
rootLogger.addHandler(fileHandler);
function log ( str )
Logger.getAnonymousLogger().info(str);
lineItemTotal = 0;
function addTotal(val)
log('B4: lineTotal ' + lineItemTotal + ' input val ' + val);
lineItemTotal += val;
log('After: lineTotal ' + lineItemTotal + ' input val ' + val);
reportContext.setPersistentGlobalVariable("addTotal", addTotal);
reportContext.setPersistentGlobalVariable("log", log);
log("Initialize");]]></method>
<method name="afterFactory"><![CDATA[log("after factory");
var hdls = Logger.getLogger("").getHandlers();
for (i = 0; i < hdls.length; i++)
Logger.getLogger("").removeHandler(hdls[i]);
hdls[i].close();
}]]></method>
<property name="eventHandlerClass">ReportEH</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="srcClassic"
id="43">
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="setInside" id="44">
<property name="dataSource">srcClassic</property>
<list-property name="parameters">
<structure>
<property name="name">param1</property>
<property name="dataType">integer</property>
<property name="position">1</property>
<expression name="defaultValue">103</expression>
<property name="allowNull">true</property>
<property name="isInput">true</property>
<property name="isOutput">false</property>
</structure>
</list-property>
<property name="queryText">select customernumber, amount
from payments
where customernumber = ?</property>
</oda-data-set>
<oda-data-set
name="setCustomer" id="45">
<list-property name="filter">
<structure>
<property name="operator">between</property>
<expression
name="expr">row["CUSTOMERNAME"].substr(0,1)</expression >
<expression name="value1">'B'</expression>
<expression name="value2">'D'</expression>
</structure>
</list-property>
<property name="queryText">select customerName,
contactFirstName, contactLastName, customerNumber
from customers
order by customerName
</property>
</oda-data-set>
</data-sets>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<property name="rightMargin">1.25in</property>
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table name="tbl" id="102">
<property name="width">100%</property>
<property name="dataSet">setCustomer</property>
<column id="115"/>
<column id="116"/>
<column id="117"/>
<header>
<row id="103">
<cell id="104">
<label id="120">
<text-property
name="text">CUSTOMERNUMBER</text-property>
</label>
</cell>
<cell id="105">
<label id="118">
<text-property
name="text">CUSTOMERNAME</text-property>
</label>
</cell>
<cell id="106">
<label id="122">
<text-property
name="text">CONTACTLASTNAME</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="107">
<cell id="108">
<data name="col1" id="121">
<expression
name="valueExpr">row["CUSTOMERNUMBER"]</expression>
</data>
</cell>
<cell id="109">
<data name="col" id="119">
<expression
name="valueExpr">row["CUSTOMERNAME"]</expression>
</data>
</cell>
<cell id="110">
<data name="col2" id="123">
<expression
name="valueExpr">row["CONTACTLASTNAME"]</expression>
</data>
</cell>
</row>
<row id="124">
<cell id="125">
<property name="colSpan">3</property>
<property name="rowSpan">1</property>
<table name="tbl1" id="128">
<property
name="backgroundColor">#FFFF80</property>
<property name="dataSet">setInside</property>
<list-property name="paramBindings">
<structure>
<property
name="paramName">param1</property>
<expression
name="expression">row["CUSTOMERNUMBER"]</expression>
</structure>
</list-property>
<column id="141"/>
<column id="142">
<property name="width">1in</property>
</column>
<detail>
<row id="133">
<cell id="134">
<data name="col3" id="145">
<expression
</data>
</cell>
<cell id="135">
<data name="col4" id="147">
<structure name="numberFormat">
<property
name="category">Currency</property>
<property
name="pattern">#,##0</property>
</structure>
<property
name="textAlign">right</property>
<method
name="onCreate"><![CDATA[addTotal(row["AMOUNT"]);]]></method >
<expression
name="valueExpr">row["AMOUNT"]</expression>
</data>
</cell>
</row>
</detail>
<footer>
<row id="137">
<cell id="138">
<label id="149">
<property
name="fontWeight">bold</property>
<property
<text-property
name="text">Total </text-property>
</label>
</cell>
<cell id="139">
<data name="col5" id="148">
<property
<property
<property
name="pattern">$#,##0</property>
</structure>
<property
<expression
name="valueExpr">Total.sum(row["AMOUNT"])</expression>
</data>
</cell>
</row>
</footer>
</table>
</cell>
</row>
</detail>
<footer>
<row id="111">
<cell id="112"/>
<cell id="113">
<text id="150">
<property name="fontWeight">bold</property>
<property name="textAlign">right</property>
<property name="contentType">plain</property>
<text-property name="content"><![CDATA[Line
Item Total
]]></text-property>
</text>
</cell>
<cell id="114">
<data name="col6" id="151">
<expression
name="valueExpr">lineItemTotal</expression>
</data>
</cell>
</row>
</footer>
</table>
</body>
</report>
Re: Own calculations [message #149405 is a reply to message #149348] |
Thu, 30 March 2006 09:31  |
Hello Scott,
I owe you a beer for resolving my problem.
I've realized what I had been doing wrong.
The worst mistake I was doing was using wrong method: onCreate for Row
instead of Data item. There is no access to row variable indeed.
onCreate of Data is much better :)
The second mistake was the code like:
lineItemTotal += row["AMOUNT"];
but creating global function for addition prevents getting 0 as total sum.
I'm now more wiser. Thanks a lot.
PS: There are three little things that bother me. I have described them
in my email and some time ago to the newsgroup. If you take a look it
will be great.
FUDForum. Page generated in 0.11341 seconds
