java file compiling problem with eclipse [message #147391] |
Tue, 21 October 2003 14:30  |
Originally posted by: jinwangcsc.hotmail.com
I met a strang problem with eclipse.
I set up the eclipse system, and created a new project with the java
files existed in my local file system. I found it can not compile in
eclipse, that is eclipse will not report any error msg, and will not
generate the corresponding class file. I checked the setting, I set up the
JRE environment, and selected the editor to "show problems before
compiling", "Highlight problems", but it doesn't work. Is there anything
else I can try?
Thanks!
Re: java file compiling problem with eclipse [message #147479 is a reply to message #147391] |
Tue, 21 October 2003 17:25  |
Originally posted by: olivier_thomann.ca.ibm.comNOSPAM
Le Tue, 21 Oct 2003 18:30:36 +0000 (UTC), jinwangcsc@hotmail.com (jin
>else I can try?
Could you please describe what you have done to get your existing
source files inside your project?
Olivier
FUDForum. Page generated in 0.06475 seconds
