Home » Archived » BIRT » Error: Report engine can not create pdf emitter?
Error: Report engine can not create pdf emitter? [message #147351] Thu, 23 March 2006 05:33 Go to next message
I have a report running fine in Eclipse environment preview/HTML and PDF.
If I deploy it to JBoss AS, I can run this report only in HTML mode.
In PDF mode I get an error message within the browser window:
Error happened while running the report
If I look into the BIRT log I found:
FEIN: return internal name for choice plain
23.03.2006 13:40:02 org.eclipse.birt.report.engine.api.impl.RunAndRenderTask
createContentEmitter
SCHWERWIEGEND: Report engine can not create pdf emitter.
run
SCHWERWIEGEND: An error happened while running the report. Cause:
org.eclipse.birt.report.engine.api.EngineException: Die Berichtengine kann
keine Erweiterung zur Bearbeitung dieses Auftrags erstellen.
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.cre ateContentEmitter(RunAndRenderTask.java:110)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:174)
org.eclipse.birt.report.services.ReportEngineService.runAndR enderReport(Unknown
Source)
org.eclipse.birt.report.viewer.aggregation.layout.EngineFrag ment.doService(Unknown
Source)
at org.eclipse.birt.report.viewer.aggregation.BaseFragment.serv ice(Unknown
Source)
at org.eclipse.birt.report.viewer.servlet.ViewerServlet.doGet(U nknown
Source)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:697)
The whole log I attached to this post.
I did the standard installation and deploying of BIRT using the online
description under:
http://www.eclipse.org/birt/phoenix/deploy/viewerSetup.php
My configuration:
JBoss 4.0.3.SP1 on SuSE Linux 10.0
Java 1.4.2_06
Eclipse 3.1.1
BIRT 2.0.0
Can someone tell me whats wrong?
Thanks a lot!
Re: Error: Report engine can not create pdf emitter? [message #147377 is a reply to message #147351] Thu, 23 March 2006 07:05 Go to previous message
solved already by myself.
Because of seom unknown reason I got the wrong iText-1.3.jar which just had
a size of 135KB.
I looked different mirrors and found several times a bigger one (1.145 MB).
After downloading that and putting it into
birt-viewer/plugins/org.eclipse.birt.report.engine.emitter.p df/lib
everythink worked well!!
Previous Topic:Report parameter combo update
Next Topic:format attribute and PDF generation
Current Time: Tue Jul 22 01:49:30 EDT 2025
Powered by FUDForum. Page generated in 0.05610 seconds
