| problems in creating new dynamic web project [message #147302] |
Wed, 16 November 2005 11:16 |
Originally posted by: kuhajeya.yahoo.com
hi guys,
i got the following error when i tried to start the new dynamic web project
what am i to correct here, upto now i have gone through numerous occasions
of reinstallin everything
Error 2005-11-15 15:25:05.571 Cannot create a resource for '.wtpmodules';
a registered resource factory is needed
java.lang.RuntimeException: Cannot create a resource for '.wtpmodules'; a
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:346)
org.eclipse.jem.internal.util.emf.workbench.ProjectResourceS etImpl.getResource(ProjectResourceSetImpl.java:262)
org.eclipse.wst.common.internal.emfworkbench.WorkbenchResour ceHelper.getOrCreateResource(WorkbenchResourceHelper.java:29 9)
org.eclipse.wst.common.internal.emfworkbench.integration.Edi tModel.getResource(EditModel.java:683)
org.eclipse.wst.common.internal.emfworkbench.integration.Edi tModel.getPrimaryResource(EditModel.java:1511)
org.eclipse.wst.common.internal.emfworkbench.integration.Edi tModel.getPrimaryRootObject(EditModel.java:1492)
org.eclipse.wst.common.componentcore.internal.ModuleStructur alModel.getPrimaryRootObject(ModuleStructuralModel.java:86)
org.eclipse.wst.common.componentcore.internal.StructureEdit. getComponentModelRoot(StructureEdit.java:495)
org.eclipse.wst.common.componentcore.internal.StructureEdit. getWorkbenchModules(StructureEdit.java:523)
org.eclipse.wst.common.componentcore.internal.resources.Flex ibleProject.getComponents(FlexibleProject.java:40)
org.eclipse.jst.j2ee.application.internal.operations.J2EECom ponentCreationDataModelProvider.getEARPropertyDescriptor(J2E EComponentCreationDataModelProvider.java:366)
org.eclipse.jst.j2ee.application.internal.operations.J2EECom ponentCreationDataModelProvider.getValidPropertyDescriptors( J2EEComponentCreationDataModelProvider.java:192)
org.eclipse.jst.j2ee.internal.web.archive.operations.WebComp onentCreationDataModelProvider.getValidPropertyDescriptors(W ebComponentCreationDataModelProvider.java:329)
org.eclipse.wst.common.frameworks.internal.datamodel.DataMod elImpl.getValidPropertyDescriptors(DataModelImpl.java:318)
org.eclipse.wst.common.frameworks.internal.datamodel.ui.Data ModelSynchHelper.setWidgetValue(DataModelSynchHelper.java:30 1)
org.eclipse.wst.common.frameworks.internal.datamodel.ui.Data ModelSynchHelper.synchUIWithModel(DataModelSynchHelper.java: 220)
org.eclipse.wst.common.frameworks.internal.datamodel.ui.Data ModelSynchHelper.synchComposite(DataModelSynchHelper.java:43 8)
org.eclipse.wst.common.frameworks.internal.datamodel.ui.Data ModelSynchHelper.synchCombo(DataModelSynchHelper.java:475)
org.eclipse.jst.j2ee.internal.wizard.ServerEarAndStandaloneG roup.createEarAndStandaloneComposite(ServerEarAndStandaloneG roup.java:107)
org.eclipse.jst.j2ee.internal.wizard.ServerEarAndStandaloneG roup.buildComposites(ServerEarAndStandaloneGroup.java:59)
org.eclipse.jst.j2ee.internal.wizard.ServerEarAndStandaloneG roup. <init>(ServerEarAndStandaloneGroup.java:51)
org.eclipse.jst.j2ee.internal.wizard.J2EEModuleImportPage.cr eateServerEarAndStandaloneGroup(J2EEModuleImportPage.java:59 )
org.eclipse.jst.j2ee.internal.wizard.J2EEModuleImportPage.cr eateTopLevelComposite(J2EEModuleImportPage.java:44)
org.eclipse.wst.common.frameworks.internal.datamodel.ui.Data ModelWizardPage.createControl(DataModelWizardPage.java:93)
org.eclipse.wst.common.frameworks.internal.datamodel.ui.Data ModelWizard.createPageControls(DataModelWizard.java:81)
org.eclipse.jface.wizard.WizardDialog.createPageControls(Wiz ardDialog.java:611)
at org.eclipse.jface.wizard.WizardDialog.setWizard(WizardDialog .java:965)
org.eclipse.jface.wizard.WizardDialog.updateForPage(WizardDi alog.java:1016)
at org.eclipse.jface.wizard.WizardDialog.access$2(WizardDialog. java:1013)
at org.eclipse.jface.wizard.WizardDialog$4.run(WizardDialog.jav a:1003)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.jface.wizard.WizardDialog.showPage(WizardDialog. java:1001)
at org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:753)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:345)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:844)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3070)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2703)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
at org.eclipse.jface.window.Window.open(Window.java:787)
org.eclipse.ui.actions.ImportResourcesAction.run(ImportResou rcesAction.java:159)
org.eclipse.ui.actions.BaseSelectionListenerAction.runWithEv ent(BaseSelectionListenerAction.java:167)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
if somebody can assist me that would be so great and helpful
thanks
Kuha
FUDForum. Page generated in 0.03232 seconds
