| Export Deployable plugins and fragments error: File specified more then once [message #13710] |
Wed, 23 July 2008 06:32  |
Originally posted by: ekkehard.gentz-software.de
I have a problem with some of my plugin projects.
if In try to export them as deployable plugins I got an error
"File xyz is specified more then once
the only difference I found out: these projects have generated
sourcefiles and so they have nested src folders like:
source.. = src/,\
src/gen/java/,\
src/man/java/,\
src/gen-pr/java/
output.. = bin/
I duplicated the plugin project, copied all to src/
then the export works without a problem
should I report this as a bug or did I something wrong ?
ekke
example from the logfile:
# Eclipse Java Compiler 0.874, 3.4.0, Copyright IBM Corp 2000, 2008. All
rights reserved.
File ..../MyClass.java is specified more than once
| Re: Export Deployable plugins and fragments error: File specified more then once [message #14503 is a reply to message #13773] |
Sat, 26 July 2008 04:34  |
has anyone an idea how to export a pde project with multiple src folders
(without copying all to src/ before)
thx
ekke
ekke schrieb:
> opened a bug http://bugs.eclipse.org/241830
> my only workaround is to move the content of all nested src folder to
> /src before exporting -
> if someone has a more comfortable workaround please let me know
> thx
> ekke
>> source.. = src/,\
>> src/gen/java/,\
>> src/man/java/,\
>> src/gen-pr/java/
>> output.. = bin/
>> ekke
>> All rights reserved.
| Re: Export Deployable plugins and fragments error: File specified more then once [message #574205 is a reply to message #13710] |
Wed, 23 July 2008 13:28  |
thx
ekke
> source.. = src/,\
> src/gen/java/,\
> src/man/java/,\
> src/gen-pr/java/
> output.. = bin/
> ekke
> rights reserved.
| Re: Export Deployable plugins and fragments error: File specified more then once [message #574502 is a reply to message #13773] |
thx
ekke
> thx
> ekke
>> source.. = src/,\
>> src/gen/java/,\
>> src/man/java/,\
>> src/gen-pr/java/
>> output.. = bin/
>> ekke
FUDForum. Page generated in 0.06920 seconds
