Home » Eclipse Projects » GEF » Creating custom shapes
Creating custom shapes [message #147244] Wed, 11 August 2004 10:29 Go to next message
Originally posted by: none.bphnx.com
In one of my EditParts' createFigure() methods, I need to create a diamond
shape.
So I extended the Polygon like this:
class Diamond extends Polygon
public Diamond()
PointList points = new PointList(4);
points.addPoint(50,0);
points.addPoint(0,50);
points.addPoint(50,50);
points.addPoint(100,50);
setPoints(points);
setOpaque(true);
then I return a new Diamond() in the createFigure() method.
However, it draws a triangle (huh? I have 4 points, not 3), and the figure
is positioned in the upper left corner of the drawing and cannot be moved.
All of my other shapes work fine, i.e. Ellipse, Rectangle, etc. so why
doesn't this work?
many thanks,
B
Re: Creating custom shapes [message #147284 is a reply to message #147244] Wed, 11 August 2004 11:08 Go to previous messageGo to next message
The points are incorrect.
Polygon does not implement translate or setBounds. It cannot be used in the
way you are using it.
I recommend that you subclass Shape, and implement drawShape and fillShape
to simply do:
Rectangle r = getBounds();
points.addPoint(r.getTop());
points.addPoint(r.getRight());
"bandrews" <none@bphnx.com> wrote in message
news:cfdafk$1cv$1@eclipse.org...
> shape.
> public Diamond()
> setPoints(points);
> setOpaque(true);
> doesn't this work?
> many thanks,
> B
Re: Creating custom shapes [message #147292 is a reply to message #147244] Wed, 11 August 2004 11:09 Go to previous messageGo to next message
The last three points you are giving it are on the same line (all have y =
50). So, the baseline of the triangle actually has 3 pts. Change 50,50 to
50,100.
> shape.
> public Diamond()
> setPoints(points);
> setOpaque(true);
> doesn't this work?
> many thanks,
> B
Re: Creating custom shapes [message #147316 is a reply to message #147244] Wed, 11 August 2004 12:03 Go to previous message
The PointList was incorrect, but even after correcting it, I still could
not move the shape in the editor for the reason Randy described. So my
Diamond class ended up like this, which works just fine! Thanks for the
advice!
public class Diamond extends Shape
private PointList diamond;
public Diamond()
protected void fillShape(Graphics graphics)
diamond = new PointList(4);
diamond.addPoint(r.getTop());
diamond.addPoint(r.getLeft());
diamond.addPoint(r.getBottom());
diamond.addPoint(r.getRight());
graphics.fillPolygon(diamond);
protected void outlineShape(Graphics graphics)
graphics.setForegroundColor(graphics.getBackgroundColor());
if (diamond != null)
graphics.drawPolygon(diamond);
> shape.
> public Diamond()
> setPoints(points);
> setOpaque(true);
> doesn't this work?
> many thanks,
> B
Previous Topic:change the GEF viewport content when receives an event
Next Topic:creating mutliple edit parts
Current Time: Fri Jul 25 04:51:20 EDT 2025
Powered by FUDForum. Page generated in 0.02550 seconds
