Home » Archived » BIRT » Can not send parameter to tablefunc with postgres 8.0.4 , Eclipse 3.2, BIRT 2.0 --> crosstab
Can not send parameter to tablefunc with postgres 8.0.4 , Eclipse 3.2, BIRT 2.0 --> crosstab [message #147233] Wed, 22 March 2006 21:11 Go to next message
2.0 --> crosstab
Hello, Every body.
I tried to use tablefunc for crosstab with BIRT by postgres 8.0.4, Eclipse
3.2, BIRT 2.0, it can work but no any parameters.
I want to send parameter to specify date between, but BIRT can not see
question mark in query of parameter to crosstab(text, text) function.
Who can tell me any way to use it.
____________________________________________________________ ________________
Part of query case 1
visitinfo.stime BETWEEN ? AND ? --> It can not work.
Part of query case 2
visitinfo.stime BETWEEN ''2005-12-01 00:00:00'' AND ''2005-12-31
23:59:59'' --> It can work
In query of Data Set...
SELECT * FROM crosstab(
'SELECT
visitinfo.coveragemain AS coveragemain,
coveragedetailtype.name AS coveragedetailtype_name,
CAST(EXTRACT(DAY FROM visitinfo.stime) AS NUMERIC) AS day_of_stime,
COUNT(visitinfo.id) AS visit_number
FROM
((visitinfo LEFT OUTER JOIN coveragedetail ON visitinfo.coveragemain =
coveragedetail.id)
LEFT OUTER JOIN coveragedetailtype ON coveragedetail.type =
coveragedetailtype.id)
WHERE
GROUP BY
coveragemain,
day_of_stime
ORDER BY 1, 2, 3;',
'SELECT day FROM day_of_date ORDER BY 1;'
AS
ct(
coveragemain INTEGER,
coveragedetailtype_name TEXT,
day1 NUMERIC,
day2 NUMERIC,
day3 NUMERIC,
day4 NUMERIC,
day5 NUMERIC,
day6 NUMERIC,
day7 NUMERIC,
day8 NUMERIC,
day9 NUMERIC,
day10 NUMERIC,
day11 NUMERIC,
day12 NUMERIC,
day13 NUMERIC,
day14 NUMERIC,
day15 NUMERIC,
day16 NUMERIC,
day17 NUMERIC,
day18 NUMERIC,
day19 NUMERIC,
day20 NUMERIC,
day21 NUMERIC,
day22 NUMERIC,
day23 NUMERIC,
day24 NUMERIC,
day25 NUMERIC,
day26 NUMERIC,
day27 NUMERIC,
day28 NUMERIC,
day29 NUMERIC,
day30 NUMERIC,
day31 NUMERIC
Yours sincerely
Report Developer
Re: Can not send parameter to tablefunc with postgres 8.0.4 , Eclipse 3.2, BIRT 2.0 --> crosstab [message #150069 is a reply to message #147233] Fri, 31 March 2006 23:23 Go to previous message
"news.eclipse.org" <czarft@gmail.com> wrote in message
news:dvt037$g85$2@utils.eclipse.org...
> BIRT
> 2.0 --> crosstab
> Hello, Every body.
> 'SELECT
> FROM
> coveragedetail.id)
> WHERE
> GROUP BY
> coveragemain,
> day_of_stime
> ORDER BY 1, 2, 3;',
> AS
> ct(
> day1 NUMERIC,
> day2 NUMERIC,
> day3 NUMERIC,
> day4 NUMERIC,
> day5 NUMERIC,
> day6 NUMERIC,
> day7 NUMERIC,
> day8 NUMERIC,
> day9 NUMERIC,
> day10 NUMERIC,
> day11 NUMERIC,
> day12 NUMERIC,
> day13 NUMERIC,
> day14 NUMERIC,
> day15 NUMERIC,
> day16 NUMERIC,
> day17 NUMERIC,
> day18 NUMERIC,
> day19 NUMERIC,
> day20 NUMERIC,
> day21 NUMERIC,
> day22 NUMERIC,
> day23 NUMERIC,
> day24 NUMERIC,
> day25 NUMERIC,
> day26 NUMERIC,
> day27 NUMERIC,
> day28 NUMERIC,
> day29 NUMERIC,
> day30 NUMERIC,
> day31 NUMERIC
> Yours sincerely
> Report Developer
Hello, Every Body.
This problem, I can solve by usin Property Binding in Data Set By use this
Query and 2 parameters.
____________________________________________________________ ___________________
"SELECT * FROM crosstab( 'SELECT visitinfo.coveragemain AS coveragemain,
coveragedetailtype.name AS coveragedetailtype_name, CAST(EXTRACT(DAY FROM
visitinfo.stime) AS NUMERIC) AS day_of_stime, COUNT(visitinfo.id) AS
visit_number FROM ((visitinfo LEFT OUTER JOIN coveragedetail ON
visitinfo.coveragemain = coveragedetail.id) LEFT OUTER JOIN
coveragedetailtype ON coveragedetail.type = coveragedetailtype.id) WHERE
visitinfo.stime BETWEEN ''" + params["date_start"] + "'' AND ''" +
params["date_end"] + "'' GROUP BY coveragemain, coveragedetailtype_name,
day_of_stime ORDER BY 1, 2, 3;', 'SELECT day FROM day_of_date ORDER BY 1;' )
AS ct( coveragemain INTEGER, coveragedetailtype_name TEXT, day1 NUMERIC,
day2 NUMERIC, day3 NUMERIC, day4 NUMERIC, day5 NUMERIC, day6 NUMERIC, day7
NUMERIC, day8 NUMERIC, day9 NUMERIC, day10 NUMERIC, day11 NUMERIC, day12
NUMERIC, day13 NUMERIC, day14 NUMERIC, day15 NUMERIC, day16 NUMERIC, day17
NUMERIC, day18 NUMERIC, day19 NUMERIC, day20 NUMERIC, day21 NUMERIC, day22
NUMERIC, day23 NUMERIC, day24 NUMERIC, day25 NUMERIC, day26 NUMERIC, day27
NUMERIC, day28 NUMERIC, day29 NUMERIC, day30 NUMERIC, day31 NUMERIC );"
The hightlight is this below text.
"...BETWEEN ''" + params["date_start"] + "'' AND ''" + params["date_end"] +
"'' GROUP ..."
Previous Topic:DataExtractionTask sometimes returns duplicate records
Next Topic:Assigning a port and IP-Adress to Report-Viewer in BIRT Designer
Current Time: Sat Jul 19 10:10:41 EDT 2025
Powered by FUDForum. Page generated in 0.07993 seconds
