| Detecting errors in XSD Parsing [message #13698] |
Tue, 11 March 2003 06:31  |
I need to be able to detect bad xsd's during parsing. For example, if
there is an XSD with a snippet like this:
<xsd:complexType name="stim">
<xsd:sequence>
<xsd:gfgfd name="This" type="xsd:string"/>
<xsd:element name="that" type="xsd:string"/>
</xsd:sequence>
</xsd:complexType>
I would like the parser to notify me somehow that the first thing in the
sequence is not a legal xsd construct. Instead it continues parsing with
complex type and says it has just one element. I tried calling
XSDSchema.getDiagnostics() but got an empty list. Does anyone know under
what conditions getDiagnostics returns errors?
Obviously there are a lot more things that can go wrong with parsing - can
anyone point me in the right direction?
Hayden Marchant
| Re: Detecting errors in XSD Parsing [message #13719 is a reply to message #13698] |
Tue, 11 March 2003 07:22  |
Hayden,
If you call XSDConcreteComponent.validate on your XSDSchema, it will validate
the whole schema. For this particular case, it will produce a diagnostic
indicating that gfgfd is not permitted.
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> Hayden Marchant
| Re: Detecting errors in XSD Parsing [message #566222 is a reply to message #13698] |
Hayden,
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> Hayden Marchant
FUDForum. Page generated in 0.03422 seconds
