Home » Eclipse Projects » Eclipse Platform » cannot use url openstream with jre 1.3
cannot use url openstream with jre 1.3 [message #147104] Tue, 21 October 2003 06:00 Go to next message
In my EditorPart i try to parse a file through the DocumentBuilder. The
method as shown below is working if i start my plugin wiht jre 1.4.1_02. If
i use jre 1.3.1_02 the "testUrl.openStream()" results in a
"java.net.UnknownHostException: C". (I have to use 1.3 because the plugins
are to run in IBM's WSAD.)
What am i doing wrong here. I saw some other threads using
Platform.resolve(URL).
Is that the path i should take, is it not legal (in a eclipse environment)
to create a url as in the excerpt below?
Again, it is working with jre 1.4.
public void init(IEditorSite site, IEditorInput input) throws
PartInitException {
IFile file = ((IFileEditorInput)input).getFile();
IPath rootPath = file.getLocation().removeLastSegments(1);
IPath testPath = rootPath.append("test.xml");
URL testURL = new URL("file://" + testPath.toOSString());
DocumentBuilder builder =
DocumentBuilderFactory.newInstance().newDocumentBuilder();
InputStream in = testUrl.openStream();
Document testDocument = builder.parse(in);
Re: cannot use url openstream with jre 1.3 [message #147637 is a reply to message #147104] Tue, 21 October 2003 09:03 Go to previous message
found it :-)
i changed
in
URL testUrl = new File(testPath.toOSString()).toURL();
"S.Witte" <switte@eniac.nl> wrote in message
news:bn2vue$6ii$1@eclipse.org...
If
> PartInitException {
Previous Topic:Programmatically import files to a Java Project
Next Topic:help:about IFile
Current Time: Wed Nov 19 05:57:28 EST 2025
Powered by FUDForum. Page generated in 0.05644 seconds
