Class loader problem with headless application in runtime workbench [message #147088] |
Tue, 21 October 2003 05:31  |
I am having a problem locating a class in a plugin when loading the class
specified as the entry class for a plugin that contributes to
org.eclipse.core.runtime.applications when launching in the runtime
workbench.
Lets call the application launch plugin A and the dependent plugin B.
The attempt to load the main class for A fails when it first tries to
reference a class from plugin B. Since I am using the runtime workbench, I
am under the impression that I don't need to create jars for my plugins. Is
this correct.
In the plugin.xml for A, B is marked as required. B also exports
everything.
B is a library plugin and does not contribute to any Eclipse extension
points.
The log file is attached. In this stacktrace A is
org.eclipse.stellation.remote.server and B is
org.eclipse.stellation.repos.msghandler.server.
!SESSION Oct 21, 2003
05:11:44.62 ----------------------------------------------
java.version=1.4.2
Command-line arguments: -pdelaunch -data e:\runtime-workspace -feature
org.eclipse.platform -dev bin -os win32 -ws win32 -arch x86 -nl
en_US -noupdate -consolelog -debug --debug 3 --database
mysql+stellation -configuration
file:e:/StellationRefactorForWVCM-1/.metadata/.plugins/org.e clipse.pde.core/e__runtime-workspace/platform.cfg -
install file:E:/Eclipse-M4/eclipse/
!ENTRY org.eclipse.core.runtime 4 2 Oct 21, 2003 05:11:44.62
!MESSAGE Plug-in org.eclipse.stellation.remote.server was unable to load
class org.eclipse.stellation.remote.server.RepositoryServer.
!STACK 0
java.lang.NoClassDefFoundError:
org/eclipse/stellation/repos/msghandler/server/Service
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:16 10)
at java.lang.Class.getConstructor0(Class.java:1922)
at java.lang.Class.getConstructor(Class.java:1019)
org.eclipse.core.internal.plugins.PluginDescriptor.internalD oPluginActivatio
n(PluginDescriptor.java:731)
org.eclipse.core.internal.plugins.PluginDescriptor.doPluginA ctivation(Plugin
Descriptor.java:200)
org.eclipse.core.internal.plugins.PluginClassLoader.activate Plugin(PluginCla
ssLoader.java:109)
org.eclipse.core.internal.plugins.PluginClassLoader.internal FindClassParents
Self(PluginClassLoader.java:181)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.find ClassParentsSelf
(DelegatingURLClassLoader.java:485)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.load Class(Delegating
URLClassLoader.java:882)
URLClassLoader.java:862)
at java.lang.ClassLoader.loadClass(ClassLoader.java:235)
org.eclipse.core.internal.plugins.PluginDescriptor.createExe cutableExtension
(PluginDescriptor.java:128)
(PluginDescriptor.java:179)
org.eclipse.core.internal.plugins.ConfigurationElement.creat eExecutableExten
sion(ConfigurationElement.java:103)
org.eclipse.core.internal.runtime.InternalPlatform.loaderGet Runnable(Interna
lPlatform.java:573)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl
..java:25)
org.eclipse.core.internal.boot.InternalBootLoader.getRunnabl e(InternalBootLo
ader.java:471)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.jav
a:854)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
..java:25)
at org.eclipse.core.launcher.Main.basicRun(Main.java:299)
at org.eclipse.core.launcher.Main.run(Main.java:765)
at org.eclipse.core.launcher.Main.main(Main.java:599)
!ENTRY org.eclipse.core.runtime 4 2 Oct 21, 2003 05:11:44.93
!STACK 0
ssLoader.java:109)
lPlatform.java:573)
..java:25)
ader.java:471)
a:854)
..java:25)
!SESSION ------------------------------------------------------------ -------
!ENTRY org.eclipse.core.launcher 4 0 Oct 21, 2003 05:11:44.125
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.reflect.InvocationTargetException
..java:25)
Caused by: java.lang.IllegalArgumentException: Application not found:
org.eclipse.stellation.remote.server.repository.
a:856)
... 7 more
Thanks in advance for any help
Jonathan Gossage
Re: Class loader problem with headless application in runtime workbench [message #147989 is a reply to message #147088] |
Wed, 22 October 2003 18:10   |
Originally posted by: John_Arthorne.oti.com_
Does either plugin define any package prefixes in their library
declarations? Example:
<runtime>
<library name="resources.jar">
<export name="*"/>
<packages prefixes="org.eclipse.core"/>
</library>
</runtime>
In this case, even if resources.jar contains org.foo.Baz, it won't be
found because it doesn't match the declared prefixes.
> workbench.
> this correct.
> everything.
> points.
> java.version=1.4.2
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 0
> at
> at
> at
> ssLoader.java:109)
> at
> at
> at
> at
> at
> at
> at
> at
> lPlatform.java:573)
> at
> at
> .java:25)
> at
> ader.java:471)
> at
> a:854)
> at
> at
> .java:25)
> !STACK 0
> at
> at
> at
> ssLoader.java:109)
> at
> at
> at
> at
> at
> at
> at
> at
> lPlatform.java:573)
> at
> at
> .java:25)
> at
> ader.java:471)
> at
> a:854)
> at
> at
> .java:25)
> !STACK
> at
> at
> .java:25)
> at
> a:856)
> ... 7 more
> Jonathan Gossage
Re: Class loader problem with headless application in runtime workbench [message #148058 is a reply to message #147989] |
Thu, 23 October 2003 04:04  |
It turns out that it was a problem with circular dependencies between the
two plugins that I had missed. It would be nice if the root cause had been
mentioned in the log because it would have saved several hours of
head-scratching.
Jonathan Gossage
"John Arthorne" <John_Arthorne@oti.com_> wrote in message
news:3F970048.10009@oti.com_...
> <runtime>
> <export name="*"/>
> </library>
> </runtime>
FUDForum. Page generated in 0.07086 seconds
