Home » Archived » BIRT » DataSet using Java Classes
DataSet using Java Classes [message #147058] Wed, 22 March 2006 11:06 Go to next message
Hello all,
I am using BIRT 2.0,Eclipse 3.1 and Tomcat 5.5. My objective is to
retrieve data from Java classes(Vectors,Hashtables) and import them into
my Dataset.
For this I wrote Java classes,which generate data from the database and
return the data in the form of a Vector(made up of String arrays).
I used JavaScript(Rhino) for importing these packages and used the
methods. My code is :
open tab
importPackage(Packages.mypackage);
myclass = new Connection();
rowdata = myclass.readData();
totalrows = rowdata.size();
currentrow = 0;
fetch tab
if(currentrow >= totalrows)
{ return(false);}
var favrow = rowdata.get(currentrow);
var Customer = favrow[0];
var Favorite = favrow[1];
var Color = favrow[2];
row["Customer"] = Customer;
row["Favorite"] = Favorite;
row["Color"] = Color;
currentrow = currentrow+1;
return (true);
close tab
rowdata = null;
tmsreportclass = null;
The DataSet shows the values in the preview results but the values dont
show in the preview tab.Could someone guide me if they had this error
before
best wishes
Re: DataSet using Java Classes [message #147960 is a reply to message #147058] Fri, 24 March 2006 14:29 Go to previous messageGo to next message
Ravi,
Maybe this will help. I have a simple project that uses the
java.lang.System object to get the properties of the system and to
display them a report.
Scott Rosenbaum
BIRT PMC
Ravi wrote:
> Hello all,
> my Dataset.
> open tab
> currentrow = 0;
> fetch tab
> { return(false);}
> row["Customer"] = Customer; row["Favorite"] = Favorite; row["Color"] =
> Color; currentrow = currentrow+1;
> return (true);
> close tab
> rowdata = null;
> before
> best wishes
Re: DataSet using Java Classes [message #148681 is a reply to message #147058] Mon, 27 March 2006 15:58 Go to previous message
hi. there is an example in the BIRT examples about how to retrieve
information from a scripted data base (java). take a look 'cause it
answers your question.
Previous Topic:Headed paper
Next Topic:Question on Total.max (wanting to evaluate over a values computed from grouped data)
Current Time: Wed Jul 23 01:19:21 EDT 2025
Powered by FUDForum. Page generated in 0.31441 seconds
