Managed Make vs Makefile [message #147002] |
Mon, 20 June 2005 10:48  |
Originally posted by: bilotta78.hotpop.com
Hello all,
I'm a newbie to the Eclipse platform in general and CDT in particular,
so I'm probably missing something obvious ... please bare with me :)
I'm using Eclipse 3.0.2 with CDT 2.1.1 under Windows XP. My build
environment is a standard MingW + MSYS + MSYS-DTK combo; it works
quite well and all paths are set up correctly (indeed, I can compile,
run, debug and even profile[1] my programs without troubles).
To begin with, I had chosen to use the "Managed Make C++ Project" and
import the (mixed C/C++) source files of my auld hand-crafted project.
Everything worked quite smoothly while editing and compiling, until I
created the actual "main" and thus linked the various object files
together. Apparently, the CDT managed make could not detect the
dependencies between some of the objects, thus linking all C-style
objects first, and all C++-style objects next. Since I have a C++
source depending on a C routine, the linkage bombs complaining about
undefined references.
So I switched to a "standard make project", which gave me the
flexibility to handle the things the way I needed them, but suddenly
autocompletion doesn't seem to work anymore ...
So my question is: is there a way to have the "managed" mode detect
the correct link order, or a way to specify it? If not, why doesn't my
standard make project find symbols across source files?
[1] does CDT have built-in support for profiling? I had to set up an
external tool for this ...
Giuseppe "Oblomov" Bilotta
Axiom I of the Giuseppe Bilotta
theory of IT:
Anything is better than MS
Re: Managed Make vs Makefile [message #147019 is a reply to message #147002] |
Mon, 20 June 2005 10:55  |
Ok, that's quite embarassing ... of course I meant "bear" not "bare".
Sigh. Not the best way to present oneself :/
"E la storia dell'umanità, babbo?"
"Ma niente: prima si fanno delle cazzate,
poi si studia che cazzate si sono fatte"
(Altan)
("And what about the history of the human race, dad?"
"Oh, nothing special: first they make some foolish things,
then you study what foolish things have been made")
FUDForum. Page generated in 0.06251 seconds
