Home » Eclipse Projects » Nebula » paintedItemListener behavior in CTableTree
paintedItemListener behavior in CTableTree [message #13683] Mon, 09 October 2006 13:08 Go to next message
Originally posted by: alnospammajor.noboxspamspoon.com
it appears that paintedItemListener can be called before the
corresponding item (cell) is intialized. is this expected behavior? or a
bug?
al
Re: paintedItemListener behavior in CTableTree [message #13726 is a reply to message #13683] Tue, 10 October 2006 08:41 Go to previous messageGo to next message
This is certainly possible behavior...
These events are fired when the container updates its internal
"paintedItems" list by determining which items will be painted to the
screen and which will not. Depending on the implementation, the cell
may wait to initialize until it is painted, in which case
paintedItemListener is called before it is ready to actually be painted.
I think the bigger problem here is that cells do not have a well defined
series of life-cycle events (partly because once you and Cal started
using them, it became apparent that the initial sequence was inadequate
:) ). This problem is also at the heart of your other issue with
getting events for your viewers' creation and disposal, and even the
order in which they initialize.
Please file a bug for this and add your thoughts on what will suit your
use cases best.
> bug?
> al
Re: paintedItemListener behavior in CTableTree [message #13769 is a reply to message #13726] Tue, 10 October 2006 14:25 Go to previous message
agreed. i guess that's why the widget is alpha ;-).
ya. what i'll do is attempt to get everything working in some fashion,
possibly with changes to the widget/viewer sources. then i'll have a
better sense of all the problems and potential solutions.
> use cases best.
hopefully i'll be able to do the above and file the bug within a week.
al
Re: paintedItemListener behavior in CTableTree [message #566491 is a reply to message #13683] Tue, 10 October 2006 08:41 Go to previous message
use cases best.
> bug?
> al
Re: paintedItemListener behavior in CTableTree [message #566564 is a reply to message #13726] Tue, 10 October 2006 14:25 Go to previous message
> use cases best.
al
Previous Topic:SWTPlus controls
Next Topic:Highlighting over item bounds
Current Time: Fri Nov 07 02:04:08 EST 2025
Powered by FUDForum. Page generated in 0.05004 seconds
