How to compile? [message #146756] |
Sat, 11 June 2005 17:28  |
Originally posted by: patrick_chang.mail.utexas.edu
I am a starter for C++. So, this is probably a silly question to most of
people here.
But, how should I compile a C++ source file on Eclipse. I download Cygwin
gcc and CDP plug in, and am able to create a C++ project and inport some
files. What is the next step to compile and run the project? I tried
"Build make target" and received message: "Error launching builder (make -k
all )
(Exec error:Launching failed)"
Does this has something to do with the GNU make. I am not femiler with the
GNU make. Some earlier message mentioned about creating a make file, but I
don't know how to do it.
Any help is deeply appreciated. Thank you.
Re: How to compile? [message #148877 is a reply to message #146756] |
Fri, 15 July 2005 02:14  |
Originally posted by: kaypro.ntels.com
My solution is this :
1. Add Cygwin Path to Window System Path.
2.
File > New > Managed Make C++ Project
A makefile for this project is created automatically and the Eclipse will
manage it.
You don't need to edit this makefile.
3.
Project > Properties
C/C++ Build -> Tools Settings Tab
GCC C++ Compiler Command edit box : g++ -> write the full path.
GCC C++ Linker Command edit box : g++ -> write the full path.
C/C++ Build -> Build command item.
Uncheck "Use default command" and write the full path.
"Patrick Chang" <patrick_chang@mail.utexas.edu> wrote in message
news:d8fl2h$icc$1@news.eclipse.org...
>people here.
> (make -k all )
> the GNU make. Some earlier message mentioned about creating a make file,
> but I don't know how to do it.
FUDForum. Page generated in 0.04413 seconds
