| text control creation on key press event [message #146721] |
Fri, 06 August 2004 05:44  |
Originally posted by: david_michonneau.hotmail.com
I would like to create a GEF editor where you could create text control on
demand whenever the user starts typing inside the editor. The layout would
be a flow layout, and you would see the cursor blinking with the mouse like
in the flowcontainer of the logic example when you drag'n'drop a control in
it.
David
| Re: text control creation on key press event [message #146761 is a reply to message #146751] |
Fri, 06 August 2004 13:07  |
> This is a 3.1 line item for GEF. We would like to start supporting Text
> entry directly into graphical views. Currently this is not easy.
What do you mean by 3.1 line item? Will it be available in GEF version 3.1?
Can you give me some hints on how to get started?
> "David Michonneau" <david_michonneau@hotmail.com> wrote in message
> news:cevjs2$ukc$1@eclipse.org...
> > Hi,
on
would
> So you could insert a native text box when the first key is pressed, and
> allow entry into the native text box using direct edit techniques.
Yes, exactly.
> like
> in
> I didn't understand this part.
I just meant you will see the blinking cursor all the time, and you can move
it around like in a text editor. In the logic example, there is a
flowcontainer control, when you drag something into it, you also see a
cursor telling you where the item will be dropped. So the goal is too see
such a cursor all the time, and the editor layout will be a flow layout
(like inside the flowcontainer).
David
FUDForum. Page generated in 0.23923 seconds
