Home » Language IDEs » ServerTools (WTP) » Broken XML editor on Mac OS X / WPT 0.7.1
Broken XML editor on Mac OS X / WPT 0.7.1 [message #146654] Wed, 09 November 2005 05:59 Go to next message
I'm running Eclipse 3.1 on Mac OS X. I installed WPT 0.7.1 from the
update site (including prereq's), primarily to check out the XML
support. My eclipse now shows that the various features and plugins are
installed, but if I try to open an XML file all I see is a blank page,
and an error in the log as below.
java.lang.NoClassDefFoundError:
org/eclipse/wst/sse/ui/internal/StructuredTextEditor
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:16 18)
at java.lang.Class.getConstructor0(Class.java:1930)
at java.lang.Class.newInstance0(Class.java:278)
at java.lang.Class.newInstance(Class.java:261)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:162)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:142)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:129)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 48)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:232)
org.eclipse.ui.internal.registry.EditorDescriptor.createEdit or(EditorDescriptor.java:252)
Either I'm missing some pre-req, or there's a bundle classpath style
issue going on. Any clues as to how I can debug this and get my
environment operational?
(I definitely have the Web Standard Tools org.eclipse.wst 0.7.1 feature
installed, and I see the related plugins in the list of installed
plugins...)
Thanks, Adrian.
Re: Broken XML editor on Mac OS X / WPT 0.7.1 [message #146667 is a reply to message #146654] Wed, 09 November 2005 06:53 Go to previous messageGo to next message
A partial solution to my own problem...
I installed 0.7.1 in an eclipse that already had 0.7.0... the install
disables the 0.7.0 version, and enables 0.7.1. BUT, not *all* the
plugins are updated to 0.7.1 version in the WPT 0.7.1 drop - some are
still at 0.7.0 level and shared with WPT 0.7.0. These plugins remain
disabled in my workspace (presumably because they are listed in the
disabled 0.7.0, even though they are *also* listed in the enabled
0.7.1). That seems like an eclipse platform bug to me.
I've disabled 0.7.1 and re-enabled 0.7.0 and that's got me going again
for the time being.
> at
> at
> at
> at
> at
> at
> plugins...)
> Thanks, Adrian.
Re: Broken XML editor on Mac OS X / WPT 0.7.1 [message #147501 is a reply to message #146667] Thu, 17 November 2005 11:35 Go to previous message
On Wed, 09 Nov 2005 06:53:42 -0500, Adrian Colyer <adrian.colyer@gmail.c=
om> wrote:
> I installed 0.7.1 in an eclipse that already had 0.7.0... the install =
> not *all* the plugins are updated to 0.7.1 version in the WPT 0.7.1 dr=
op - some are still at 0.7.0 level and shared with
> WPT 0.7.0. These plugins remain disabled in my workspace (presumably b=
ecause they are listed in the disabled 0.7.0, even
> though they are *also* listed in the enabled 0.7.1). That seems like a=
I would appreciate a bugzilla being opened on this, and this scenerio.
It might well be we did not create our update package correctly, so, I p=
ersonally
don't mind where you open the bug. But ... I do want to make sure we get=
'updates'
working well and as expected, so we'll get someone to take a deeper look=
... if you
open the bug. (I'm not sure we'll change/fix anything in 0.7.1 . but wan=
t to be sure we
understand the issues better as we move forward).
Previous Topic:cannot find web.xml
Next Topic:need a help
Current Time: Sat Nov 08 23:19:36 EST 2025
Powered by FUDForum. Page generated in 0.03642 seconds
