Birt Chart [message #146651] |
Tue, 21 March 2006 15:56  |
Getting error when inserting chart into a report design.
------Message----------
Problems occurred when invoking code from plug-in: "org.eclipse.jface".
------Exception Stack Trace---------
java.lang.NoSuchMethodError:
org.eclipse.birt.chart.model.type.impl.TypePackageImpl.freez e()V
org.eclipse.birt.chart.model.type.impl.TypePackageImpl.init( TypePackageImpl.java:182)
org.eclipse.birt.chart.model.type.TypePackage.<clinit>(TypePackage.java:68)
org.eclipse.birt.chart.model.layout.impl.LayoutPackageImpl.i nit(LayoutPackageImpl.java:154)
org.eclipse.birt.chart.model.layout.LayoutPackage.<clinit>(LayoutPackage.java:67)
org.eclipse.birt.chart.model.attribute.impl.AttributePackage Impl.init(AttributePackageImpl.java:839)
org.eclipse.birt.chart.model.attribute.AttributePackage.<clinit >(AttributePackage.java:69)
org.eclipse.birt.chart.model.data.impl.DataPackageImpl.init( DataPackageImpl.java:225)
org.eclipse.birt.chart.model.data.DataPackage.<clinit>(DataPackage.java:67)
org.eclipse.birt.chart.model.component.impl.ComponentPackage Impl.init(ComponentPackageImpl.java:201)
org.eclipse.birt.chart.model.component.ComponentPackage.<clinit >(ComponentPackage.java:67)
org.eclipse.birt.chart.model.impl.ModelPackageImpl.init(Mode lPackageImpl.java:133)
at org.eclipse.birt.chart.model.ModelPackage.<clinit>(ModelPackage.java:67)
org.eclipse.birt.chart.model.impl.ChartWithAxesImpl.eStaticC lass(ChartWithAxesImpl.java:176)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eClass(BasicEObj ectImpl.java:785)
at org.eclipse.emf.ecore.util.EContentsEList.<init>(EContentsEList.java:44)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eContents(BasicE ObjectImpl.java:338)
org.eclipse.emf.ecore.impl.BasicEObjectImpl$1.getChildren(Ba sicEObjectImpl.java:362)
org.eclipse.emf.common.util.AbstractTreeIterator.hasNext(Abs tractTreeIterator.java:87)
org.eclipse.birt.chart.ui.swt.wizard.TaskSelectType.updateAd apters(TaskSelectType.java:787)
org.eclipse.birt.chart.ui.swt.wizard.TaskSelectType.refreshC hart(TaskSelectType.java:1029)
org.eclipse.birt.chart.ui.swt.wizard.TaskSelectType.placeCom ponents(TaskSelectType.java:183)
org.eclipse.birt.chart.ui.swt.wizard.TaskSelectType.getUI(Ta skSelectType.java:169)
org.eclipse.birt.core.ui.frameworks.taskwizard.WizardBase.sw itchTo(WizardBase.java:354)
org.eclipse.birt.core.ui.frameworks.taskwizard.WizardBase.op en(WizardBase.java:208)
org.eclipse.birt.chart.ui.swt.wizard.ChartWizard.open(ChartW izard.java:175)
org.eclipse.birt.chart.reportitem.ChartReportItemBuilderImpl .open(ChartReportItemBuilderImpl.java:207)
org.eclipse.birt.report.designer.internal.ui.editors.schemat ic.extensions.ExtendedElementToolExtends.preHandleMouseUp(Ex tendedElementToolExtends.java:55)
org.eclipse.birt.report.designer.internal.ui.palette.ReportT emplateTransferDropTargetListener.handleDrop(ReportTemplateT ransferDropTargetListener.java:136)
org.eclipse.gef.dnd.AbstractTransferDropTargetListener.drop( AbstractTransferDropTargetListener.java:171)
org.eclipse.jface.util.DelegatingDropAdapter$3.run(Delegatin gDropAdapter.java:211)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1044)
at org.eclipse.core.runtime.Platform.run(Platform.java:783)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 8)
org.eclipse.jface.util.DelegatingDropAdapter.drop(Delegating DropAdapter.java:209)
at org.eclipse.swt.dnd.DNDListener.handleEvent(DNDListener.java :65)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:867)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:852)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:6 60)
at org.eclipse.swt.dnd.DropTarget.notifyListeners(DropTarget.ja va:480)
at org.eclipse.swt.dnd.DropTarget.Drop(DropTarget.java:405)
at org.eclipse.swt.dnd.DropTarget.access$7(DropTarget.java:350)
at org.eclipse.swt.dnd.DropTarget$3.method6(DropTarget.java:236 )
org.eclipse.swt.internal.ole.win32.COMObject.callback6(COMOb ject.java:117)
at org.eclipse.swt.internal.ole.win32.COM.DoDragDrop(Native Method)
at org.eclipse.swt.dnd.DragSource.drag(DragSource.java:277)
at org.eclipse.swt.dnd.DragSource.access$0(DragSource.java:267)
at org.eclipse.swt.dnd.DragSource$1.handleEvent(DragSource.java :161)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
-------Session Data-----------
eclipse.buildId=I20050627-1435
java.version=1.5.0_05
Command-line arguments: -os win32 -ws win32 -arch x86
Any help would be highly appreciated.
Thanks.
FUDForum. Page generated in 0.04618 seconds
