Home » Language IDEs » Java Development Tools (JDT) » Open Declaration -> yes || Search Declaration -> no?
Open Declaration -> yes || Search Declaration -> no? [message #146585] Mon, 01 March 2004 13:03 Go to next message
Originally posted by: chrismo.clabs.org
Any reason why Eclipse (2.1.2) would be able to successfully find a
class when using Open Declaration on the context menu, but not find the
very same class when doing a Type/Declaration search from the Java
Search dialog?
Chris
http://clabs.org
Re: Open Declaration -> yes || Search Declaration -> no? [message #146736 is a reply to message #146585] Tue, 02 March 2004 07:48 Go to previous messageGo to next message
Did you see my answer to your previous post? I think you're having problems
with your build path. Try solving those first.
Jerome
"Chris Morris" <chrismo@clabs.org> wrote in message
news:c1vtns$kn6$1@eclipse.org...
> Search dialog?
> Chris
> http://clabs.org
Re: Open Declaration -> yes || Search Declaration -> no? [message #146929 is a reply to message #146736] Tue, 02 March 2004 10:25 Go to previous message
I did, sorry I didn't follow up. I'd checked build paths, did diffs on
the .project and .classfile files on the two machines, did a full binary
diff of the Eclipse installs (which normally has some differences, so I
could have missed something that matters), CLASSPATH env var comparisons ...
Anyway, I tried installing 3.0 M7 on the 'bad' machine and it magically
started working, using, AFAIK, the same .project/.classpath files and
same settings as before ... weird.
Chris
http://clabs.org
Previous Topic:Java app launching
Next Topic:Very limited search results
Current Time: Sun Nov 09 12:25:04 EST 2025
Powered by FUDForum. Page generated in 0.74805 seconds
